Question about Archos AV400 Digital Media Player
Archos AV400 screen is broken, looks like a black stain over 50% of screen, the glass outer screen is not broken or cracked its the lcd underneath.
Posted by illusio12 on
Anonymous
    New Friend:
Who replace the screen for an archos av400 and what is the price
Posted on Sep 07, 2010
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
I cannot accesss my archos av400 20GB via usb. I tried different cables. If I select Hard drive, windows dont detect my archos at all but when I select windows device, my windows detect the archos but not...
Your windows is installed on FAT 32 partition, so it is not recognized partitions bigger than 4 Gb. Change to NTFS. ATTENTION ! All informations on your computer will be lost. Do this only after saving your private files !!!
Sep 11, 2017 | Archos AV400 Digital Media Player
My 50 inch toshiba is black only on one side i have half of a good tv
Ur backlight video board is the problem,must change for this problems.Check for crack or damage the on the LCD screen,tv it worthless,if the LCD screen is dead,broken LCD screen glass.
Nov 24, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My son threw a ball and hit the screen cracks all over can this be fixed with a new screen or is it junk now really bright light shows through all the crack marks
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Jun 02, 2009 | Toshiba 42HL67 42 in. LCD Television
Sanyo VPC T700 broken lcd
hi, if you want to buy a replacement lcd screen, pls contact us by email [email protected]. we are direct supplier for camera repair parts, you could get more about us from www.think-tec.com
Dec 09, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Archos AV400 Power Adapter
wallwart is model # trc-05-1600 made by group west I have one, though I cant let it go... BUT may battery is dead and i have to unscrew? the back to replace it. Got any tips for me?
Sep 30, 2008 | Archos AV400 Digital Media Player
Broken screen
i have the archos 404 with a crack screen need to get it fix
Jul 20, 2008 | Archos 404 Digital Media Player
It won't start. my Archos AV400
Probably a bad connection from the drop, or one of the ribbons has gotten loose. The only way to tell, is to open up the player and examine it and look for damage.
Sep 05, 2007 | Archos AV400 Digital Media Player
Archos
This is a hardware problem, and it might be a ribbon cable that has come loose or cracked. Also, the backlight might be the problem. The av400 series was the same lcd as the av300 series and can be found at www.hotmp3technology.com. Haven't found any other place that stocks lcds.
Nov 13, 2006 | Archos AV400 Digital Media Player
Archos AV400 Digital Media Player Logo
138 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
