Question about Microsoft Xbox 360 Console
How do you connect xbox 360 to wi fi got the receiver but cannot pick up my modem
Posted by jannice_07 on
Anonymous
    Problem Solver:
  • 12 Answers
Make sure you have Turned on the console and navigated to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Make sure that is how it is set-up and then try to preform a connection test
Posted on Oct 14, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Am using sony ericson x10 and how to find the internet connection without using the wi fi?
I guess you could use the mobile-network?
Settings > Network & Wifi
There you will find something like mobile network / mobile-traffic or something, I havee a norwegian phone, so I don't know what it is called on the enligsh versions.
Dec 22, 2012 | Sony Ericsson XPERIA X10 Mini E10i...
Cannot get connection to wireless router from xbox live console
I do just want to check, you are using a wireless adapter, correct? I don't mean to sound condescending at all, but there are many people who think that the Xbox 360 natively can connect to wireless networks when it, in fact, can not.
The above is assuming that you are using a generation 1 Xbox 360 like you have pictured. Some of the newer models do have native wi-fi capabilities.
Assuming you do have a wireless adapter, or that you are using a new Xbox, the best thing to do from here is to check your settings in your system menu and make sure everything is correct for the router you are using. The best place to look for help for this is the Xbox customer support page for wi-fi connections, which can be found here:
http://support.xbox.com/en-us/pages/xbox-live/get-started/connecting/wireless.aspx
May 12, 2011 | Microsoft Xbox 360 Console
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do I setup my wi-fi on the new xbox 360? Do I have to have the internet adapter i believe, even if wi-fi is built into the system?
Go into your internet test glade, and search for locatons to connect to, if the adapter id plugged in you should be able to search for wireless signals. Connect to yours or the best connetion, but just know, WEP or WEP2 connections are password guarded.
Jul 17, 2010 | Microsoft Video Game Consoles & Games
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
360 lagging like crazy on live
Try restarting the whole test to connect to xbox live turn off you7 Wi-Fi. When I re-hooked mine up it worked fine. I dont know why but you could always give it a shot.
Apr 17, 2009 | Microsoft Xbox 360 Console
Xbox 360
You cannot use the netgear wi-fi adapter as the xbox 360 will not be able to detect it. I suggest buying the wi-fi adapter specifically manufactured for the xbox360
Nov 30, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
62 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
