How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
  • Anonymous Oct 15, 2009
    Thanks for the information.After a thorough check on the Tv's circuit it appears it a Beko 14" Chasis. So i need the procedure to unlock the Key--- displayed on the Tv when turned on and the Background is Blue.I've tried inputing some numbers into the 3 hyphen displayed next to Key but all to no avail. Counting on your technical assistance. Looking forward to your response ASAP....
    Thanks.
ZJ Limited
  • 17,970 Answers
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Posted on Oct 14, 2009
  • 1 more comment
  • ZJ Limited
    ZJ Limited Oct 14, 2009
    Also can read this information:
    OTHER TELEVISION BRANDS:
    If you do NOT see the code to enter the service mode on your television:
    I do NOT have the code to enter service mode for that
    particular model. There's no point in sending me email asking if I have
    the code to enter service mode on model "XYZ", because if I had the
    procedure it would be listed in this section. If you do come across a
    model or manufacture that I do not have listed here please email it to me so that I can include it in future releases of this document.
    Good luck.
  • ZJ Limited
    ZJ Limited Oct 15, 2009
    maybe this document can helped: BEKO-L6B-PDP-Service-Manual
    Good luck.
  • mikedb18
    mikedb18 Oct 22, 2012
    toshiba 56hm66. there is a way to get to menu without tv on to fix no audio. anyone know how
Hi i need the code for my beko tv
0039,0036,0031. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 21, 2014 | Beko 324250WN 28" TV
How to unlock the child lock without remote oc philips portable tv
No, I 'm afraid not my friend. Maybe you have a friend or someone you know who has a Philips or Magnavox remote control so you can unlock your set.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Jun 28, 2011 | Televison & Video
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
Beko fst.nicam.fastext
LOST THE ROMOTE FOR THIS T.V. GOT A ONE FOR ROMOTE CONTROL BUD ... BUT THE ONE FOR REMOTE CONTROL IS ASKING FOR THE T.V DEVICE CODE COULD ANY 1 HELP ME OUT THERE ??
Feb 16, 2010 | Beko 324250WN 28" TV
WHAT IS THE CODE FOE A BEKO TV ON A BD-512?
There is no such thing as a 'universal' remote; even the 'learning' remotes do not learn from every original. There may not be any code for all the devices you own. I suggest always checking the remote manufacturer's website for codes on all equipment you wish to control before buying any remote.
If you need an original remote, try remotes.com
Feb 15, 2010 | Beko 142746 TV
Beko television code for universal remote control
i need a code 4 a beko television universal remote control urc22b
Sep 22, 2009 | Beko 324250WN 28" TV
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Televison & Video Logo
586 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
