If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
I recommend that your contact the company cables, and consult if the john lewis control is compatible witht Bt box. They will instruct if this will be work. Otherwise you must replace by other remote such as R.Schack that work very well.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
