Question about IBM eServer BladeCenter HS20
Installing windows 2003 server on IBM bladecentre HS20. Gone through the preliminary installation configurations using the blade's setup steps. Prompted to remove disk after setup has completed copying files to a temp. folder. At this point it get stuck in setup is coping file > searching shell32.dll
Posted by onyebuuchii on
Anonymous
  • 763 Answers
Shell32.dll file is very important windows system files.It control all users grapgical settings, icons, anything related to graphic user interface of the Operating system.If shell32.dll cannot be copied during installation,the system never gets to GUI mode.Try using a New CD/DVD.it will solve your problem.
Posted on Dec 23, 2009
I get physical memory dump error while installing windows server 2003
This is a hardware compatibility issue. (Most times) when installing server 2003 and it keeps dumping memory. Check to make sure your system is the correct configuration for the Windows Server 2003.
Good Luck .
C2Solutions
When i install MS windows server 2003 in IBM x3400 server it gives me message that setup could not find any hard desk installed in your computer.
The hard drive may only needs the data cables re-connecting or the hard drive may be faulty.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Then the hard drive needsto be replaced in the computer, Windows installed and the computer's device drivers plus your programs etc. to get a functioningcomputer again.
I WANT TO INSTALL 2003 SERVER ON IBM X236 BUT IT IS SHOWING NO DRIVE PRESENT
Use the IBM configuration disk and it should be able to prepare the server for what ever OS you need to install. If you don't have it then, try redoing RAID and reformat the hard drives and try again..You can probably hit F6 during the initial portion of the install and supply the necessary SATA drivers on a floppy and get it to install. You will probably need a USB floppy though unless your server has a floppy drive.
Insert your Microsoft Server 2003 Installation disc into the CD/DVD-ROM drive and boot the server from the installation disc. Microsoft Setup will load the files it needs to perform an installation. Press "Enter" to setup and install Windows.
  • 2 Press "F8" to accept the Microsoft License Agreement.
  • 3 Create a new partition to install the operating system onto by selecting the "Unpartitioned Space" and pressing "C." If there is no unpartitioned space, highlight and delete all of the other partitions on the hard drive by pressing "D." Set the partition size to the "Maximum Size" and press "Enter."
  • 4 Format your new partition with the "NTFS" or the "NTFS (Quick)" option. Windows setup will format your hard drive and load the installation files. Your IBM Netfinity will restart and installation will continue.
  • 5 Select language and regional setup information, then press "Next." Enter your name and company name, then press "Next." Enter your Windows 2003 Server Product Key and press "Next."
  • 6 Select the licensing mode you would prefer to use and press "Next." Create an administrative account and password and press "Next." Enter the current time and time zone and press "Next."
  • 7 Setup your Network information by naming the server and defining how it will connect through the net. Press "Next" to navigate through the network setup screens. Windows Setup will finish the installation process and provide you with a log-in screen to use your computer.
  • If you delete old partitions from the hard drive to install Windows Server 2003, you will lose all information on those partitions.
    1helpful
    I TRY TO INSTALL WINDOWS 2003 SERVER, HDD NOT DELTECTING
    • First you have to Run the setup utility and make sure that all the devices are integrated well and function properly.
    • Please use the user Guide from here.
    • Read the instructions on How to Install Windows Server 2003 from here.
    Please be kind enough to rate the answer.
    Thanks for using Fixya!
    Hp ml350g4 p server hang on diagonestic screen, unable to set standard boot order(ilo)
    To repair your installation of Windows, follow these steps:
    1. Insert the Windows Server 2003 CD in the CD-ROM or DVD-ROM drive.
    2. If the Windows CD displays the What would you like to do? menu, click Exit.
    3. Turn off your computer, wait ten seconds, and then turn your computer back on.
    4. If you are prompted to start your computer from the CD, do so.
    Note You must be able to start your computer from the Windows Server 2003 CD-ROM to run Windows Setup. Your CD-ROM or DVD-ROM drive must be configured to do so. For information about how to configure your computer to start from the CD-ROM or DVD-ROM drive, see the documentation that is included with your computer, or contact your computer manufacturer.
    5. After Setup starts, press ENTER to continue the setup process.
    6. Press ENTER to select the option To set up Windows now, press ENTER. Do not select the Recovery Console option.
    7. Press F8 to accept the licensing agreement.
    Setup searches for previous installations of Windows.
    * If Setup does not find a previous installation of Windows Server 2003, you might have a hardware failure.
    Hardware failures are beyond the scope of this article. See a computer hardware specialist for more help or try the Hardware troubleshooter. For more information about the Hardware Troubleshooter, see the Windows Server 2003 Help topic "Using Troubleshooters."
    * If Setup does find a previous installation of Windows Server 2003, you may receive the following message:
    If one of the following Windows Server 2003 installations is damaged, setup can try to repair it. Use the up and down arrows to select an installation. To repair the selected installation, press R. To continue without repairing, press ESC.
    Select the appropriate Windows Server 2003 operating system installation, and then press R to try to repair it.
    * Follow the on-screen instructions to repair the installation.
    Notes
    o You might have to change the boot drive sequence in your BIOS settings to successfully start your computer from the Windows Server 2003 CD. Contact the manufacturer of your computer, or see your manufacturer's documentation, for more information.
    o If you cannot start your computer from the Windows Server 2003 CD, you might have a CD-ROM or DVD-ROM drive failure or other hardware failure.
    o After you repair your Windows Server 2003, you may be required to reactivate your copy of Windows Server 2003.
    4answers
    Problem with DG31PR board while loading windows 2003 server.
    check HDD and RAM, make sure your HDD new formated
    2answers
    IBM xSeries 360 Server support Win 2003?
    The good news is IBM says it will work, the BIOS might require an upgrade. I would consult ibm.com and get the latest updates for your hardware after that insert CD and reboot!
    Have Fun.
    7helpful
    4answers
    How to install windows server2003in ibm server x3400
    The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
    Good Luck
    Franklin
    C2Solutions
    4helpful
    2answers
    New install scsi hard disk no detect in ibm x3400 server
    you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
    Regards Al "alstech"
    SCSI hard disk is not detecting in IBM xSeries 346 Server
    Hi
    While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
    IBM eServer BladeCenter HS20 Logo
    Top IBM Computers & Internet Experts
    Ekse
    Michael Thomas
    Michael Thomas
    Jax Planet
    Jax Planet
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
