Depends- is it new enough to be worth spending the money? top load or front load? out of warranty? does 200 usd include labour? could contact manufacturer and find if a re-furbished board is available for a lesser price.
could you replace the board yourself??
also consider- is there an on-board fuse that could be replaced? and- what caused the failure? bad component on board- or a fault somewhere else in the machine? if the machine otherwise has been dependable, and would cost 8-900 usd to replace, then do the math. if it's getting a little 'long in the tooth', may want to replace it! times are tight, i know!!
may try finding a newer used machine with some kind of limited warranty (30-60 days). do on-line check for reliability ratings.
good luck!
Testimonial: "Great reply thanks."
If you need a part check out www.appliancepartssolutions.com
