Question about Bosch Classixx WFL 2066 Front Load Washer
Help with child lock instructions
I've inherited aBosch classixx 6 1200 express without instructions and i need to know how to turn on the child lock!!
Posted by judibigeyes on
Anonymous
    Sergeant:
  • 228 Answers
To my knowledge there is not a child lock on this model its at the basic end of the range only upper range models have this feature.sorry.
Posted on Oct 20, 2009
I have accidentally put the child lock on my washing machine but have mislaid my instruction manual. Please help.
A re-posting of a Fixya answer:
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Feb 23, 2018 | Bosch Washing Machines
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
How do i get the child lock off to operate the machine please
You have probably inadvertently activated the child lock. You can start a cycle still, but you will need to hold the start button for approx 5 secs. Check you user guide for deactivation instruction.
use link to get manual if needed
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Jul 08, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jan 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
When I select a cycle the -0- is displayed and the lock symbol.
YOU PROBABLY HAVE THE CHILD LOCK ACTIVATED GENERALLY HOLDING THE LOCK BUTTON IF THERE IS ONE OR THE START BUTTON FOR 5 SECS OR MORE WILL TURN IT OFF ALLOWING NORMAL USE
Sep 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
589 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
