Question about Hitachi 46BX01B 46" Rear Projection Television
I have a 46" rear projection TV by Hitachi that is about 10 years old. It is a standard definition TV. The remote that came with the TV will not allow me to adjust the picture quality (it seems to bright) is there any way of manually adjusting the picture. When I put the remote into picture adjust it says to hit enter to make adjustments but nothing happens when I hit enter.
Posted by hansonbuck on
Anonymous
  • 541 Answers
Make sure there is not a lock turned on. Hitachi loves to use locks.
Posted on Oct 14, 2009
TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
Dec 15, 2008 | Hitachi 46GX01B 46" Rear Projection...
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
46 in hitachi projection screen -15 years old-won't turn on
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Aug 01, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
46" Rear Projection Hitachi - Green / Yellowish Screen
daveT29 - I had my brightness cranked, too. The picture went dark and off-color after moving the TV from one corner of the living room to another.
After waiting for the TV repairman for about 4 weeks, I "fixed" it myself. Take the front panel off (4 screws, then a black panel) and blow out all the dust. I was afraid to use a swiffer duster because of the static electricity, so i just used with my mouth blowing powers.
That's it. Seriously.
Jan 09, 2008 | Hitachi 46F500 46" Rear Projection...
Set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Hitachi 46BX01B 46" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
