Hi i have a RCA P52937SG with the bowing of the top and bottom of the screen and the picture looking like 3D at the edges.I unpluged the convergance module power supply and the picture got much worse so i guess the convergance psu is ok .The convergance module looks like 6 heat sinks with 3 transistors or regulators attached to each one.What should i check and test and if all else fails were do i get a new module and what is the part number i should be looking for? The chassis number is ptk195m4b thanks other part numbers are ctc195m4 and 15888430
Check on the power board - 2 diodes CR19713 and CR19710 DC voltage - around +45VDC and -45VDC- Check both diodes at the plug side CR19713 should be the - 45VDC. Rca Has service bulletin about replacing these 2 diodes even if they check ok.
Part #227066
Check any other supplies feeding the convergence board - and check /compare the transistors on the conv. brd heat sinks - sounds like your on the right path
Thanks Johnny what are the correct voltages i should see?Are there three supplies one for each color? and where should i take the mesurment from there is a multi plug leaving the board at one end i guess thats where i will get my voltages?
Hi Johnny
Diode CR19713 -44.37vDC and CR19710 +45.07vDC
what else can i look at your help is apreciated.I think i will take the board out and change them and look for any cold solder joints
