Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
this helps.
You have a component not up to specs in your input 2 circuitry possibly a capacior. You would need a service manual to locate which item that isnt up to its rating. you can purchase the service manual for your set for 12.99 at the following link. They will emal it if you send them an email requesting it. http://servicemanuals.vstore.ca/
