Televison & Video Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
51'' Philips rear projection TV with color issues
I have a 51'' Philips 51PP9100D/37 that I recently bought used. The TV is supposedly less than two years old. The first thing I noticed is that the picture looks to have a yellow tint to it.
For example, white writing appears yellowish to me. I then noticed that there is a bluish white spotlight effect towards the middle of the screen which actually appears to move a bit at times. A better example of that would be when it is a black screen with white credits, all of the writing appears to have a light shining from behind creating a bright cloud around the writing.
Dark scenes are extremely dark, colors are way off, but in general the clarity is not too terrible...it's not unusable. I don't have HD hooked to it yet but it doesn't matter if I'm watching satellite or a DVD, I get the same problem.
I found info in the forums for adjusting color convergence, which I attempted with little to no results. This tv only gives two color options in the menu; red and blue. I can adjust the red just fine, but when I adjust the blue, the spotlight cloud effect is so bad behind the crosses that I can't tell if they're off or not.
Any suggestions/diagnosis?
Thank you!
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Oct 14, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
Helped
126486
Points
1217
Philips has had a big problem with there coolant fluid becoming cloudy. The only way to clear it up is to have the fluid changed. With every projection crt tv there is a layer of cooling fluid between the face of the crt and the lens. This coolant cools the face of the crt. Over time the coolant breaks down and the light coming through gets distorted. The crt's have to be removed from the set to do this.
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
My 51pp9100d/37 philips TV doesn't have any sound.
This set has a "small signal board" The board is about 3x5 inches and plugs into board on far left as seen from back of set.
A lot of these fail:
low sound
no sound
intermittant sound
no remote functions
no channel up or down
etc etc
Last time I looked board was around 100 exchange rebuilt
1helpful
I have an 51pp9100d/37 Phillips Tv, and i the red and green colors on the picture are skewed to a weird, almost sideways, S shape. I was wondering if this is an easy fix and cheap, i don't really know...
From what you have said it seems that you need to replace the Convergence ICs, they are Big Black ICs and will have Part number on them ,example STK392-110
Mats Electronics has Parts $9.95 each IC. 1-800-628-1118
PTS rebuilts boards 1-800-844-7871
I Specifically have a 2005 Phillips 50" Projection
on your remote go to menu,then push picture then scroll down to converge then depending on what color is out of line you will push that,then what ever is out of line you line it up by the up arrow.if that don;t work then there are parts on your board gone bad.
1helpful
I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
PIP does not work
The PIP can only use one tuner at a time, if one is on CATV, the other has to be on an AV input. you would need a catv box for the AV input for this to properly function.
2answers
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
