Having issues heating up to temp takes more than two hours just to heat to 200 Degrees any ideas?
Your bake element could be burned out & the oven is trying to get to temp with the broil element only. see if it is getting warm or if it has a burnt spot on it. if it seems to be ok, you may have a bad oven sensor. the oven sensor should have a reading of at least 1100 ohms. let me know if i can be any further help.
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
