Question about Panasonic Lumix DMC-LC20 Digital Camera
Panasonic DMC-TZ7 BRAND NEW, INSERTED 16GB SDHC CARD, BUT IT DONT WORK "MEMORY CARD ERROR" PLEASE CHECK THE CARD.HAVING TRIED ANOTHER 16GB I AVE THE SAME PROBLEM...ANY IDEAS
Posted by mjclements on
Ty Price
    Brigadier General:
  • 11,967 Answers
Did you format the card in the camera first to initialize it?
Posted on Oct 14, 2009
Memory card error for the Panasonic DMC-TZ1
What type and size memory cards? The DMC-TZ1 works with SD cards 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2013 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix LX3
We may be able to recover the data for you. If it is a logical recovery, we can do it for as little as $59.95! We only charge if we are successful. If we cannot recover the data, we only charge you for return shipping.
http://htcilabs.com/services/data-recovery-services/
Aug 01, 2012 | Panasonic Lumix DMC-LC33 Digital Camera
I have a DMC-TZ7 and purchased a SDHC memory card RP-SDW08GE1K as this is shown by panasonic to be compatible with this camera. When the card is inserted all I get is "memory card error- please check the...
Well, a Panasonic card should work in a Panasonic camera, if they say it will, so ...
First:
Check that the write-protect switch on the card is not set to read only. It should be toward the contact edge of the card.
Next:
Put the card in and try to format it in the camera.  If it takes the formatting then you should be OK
Finally:
If the above does not work, then check that your camera works with a smaller cheaper SD card (say a 1gb size).  If the camera is happy with that then take the SDHC card back to where you bought it and ask for a refund or replacement. Take the camera with you.
Feb 27, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
New 16GB SDHC class 6 card not recognized by my lumix TZ7
You a correct...your camera can use the card. Is the slide switch on the side of the card in the unlocked position? Go into the camera menu without the card and find "reset"...follow the on-screen instructions. Then try to format the card again. Let me know what happened.
Dec 18, 2009 | Panasonic Lumix DMC-ZS3 Digital Camera
Got the dmc-ts1 couple of weeks ago, can't read SDHC cards
The card needs to be formatted in the camera to work properly.
Sep 06, 2009 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
Sammi James - number 1 spammer expert on FIXYA
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-LC20 Digital Camera Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
