Frigidaire FEB30S5D Electric Single Oven Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aluminium foil does covering aluminium foil and keeping in oven will catch fire
Anonymous
Level 3:
  • Master 491 Answers
  • Posted on Oct 13, 2009
Anonymous
Master
Level 3:
Answers
491
Questions
0
Helped
164180
Points
1521
NO IT SI NOT FLAMABLE ,
LOFRA LEF9EGP gas stove/electric oven - aluminium foil touching bottom element - is this safe?
The tin foil is there to reflect the heat and the lagging is to stop the heat from escaping.
I would think the foil should not be touching the element but otherwise, your description sounds plausible.
Mar 26, 2022 • Ovens
1helpful
I melted a plastic bowl in oven I scraped most of it out while it was hot but now I have thin spots of plastic film, I need to know how to clean without ruining the surface of my oven cavity
Warm the oven to 100c allow to cool for 15 mins with door open then lightly scrub with a ball of aluminium foil this won't scratch ad foil is softer than the oven lining
Jan 06, 2018 • Ovens
How do you clear Clock/Timer on a 1-year-old Viking Electric oven (Model # VESO1302SS)?
PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m3500217_F20669.pdf
Viking RangeClocks and Timers ... the potential risk of fire, electric shock, personal injury or damage to the appliance as a result ... NEVER use aluminum foil to cover oven racks or oven bottom. ... Keep area around appliance clear and free from combustible materials, .... 1. Push and hold the "MIN/SEC TIMER" and "BAKE TIME" buttons.
2answers
Will aluminum foil protect credit cards
No! They make special cases for protecting them from radio wave theft devices.
Oct 06, 2015 • Ovens
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Jan 01, 2014 • Ovens
What brands of aluminum foil are safe for convection ovens
Any good quality heavy duty foil should do. Temperatures in conventional ovens never come near the melting point of aluminium, although all aluminiums for a slight health risk.
6helpful
2answers
I have baked on aluminun foil on the bottom of my self clean oven did the cycle to self clean and the aluminum foil is still stuck on the bottom what can I do to remove it without ruining the surface
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
1helpful
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
1helpful
Tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
