Question about Reebok New York Giants Eli Manning Jersey
I have a reebok rev 11301 treadmill the oil light has come on but i dont have my manual and i dont know were the oil goes
Posted by carljones197 on
Anonymous
  • 40 Answers
It goes in the oil container
Posted on Oct 13, 2009
1 Related Answer
Anonymous
SOURCE: i have a reebok rev
just pick the rubber belt (on which you run) and put oil under it 1Ml on front left and 1ML on front right
Posted on Nov 20, 2010
Reebok premier running machine (re-11301) keeps tripping electrics... Loose earth wire located near to on off switch... Where does it fit... Wiring diagram required.. Please help
Dear Sir:
See this block diagram that i did for you help.
5_9_2012_10_31_52_am.gifyou will only 2 wires, one go to the input the another to output it does matter which color go to the input or output.God bless you
May 08, 2012 | Reebok Exercise & Fitness
Nov 12, 2010 | Reebok New York Giants Eli Manning Jersey
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
I have just bought a Reebok 3 series treadmill.Do
If manufacturer and google are of no help, ask them. They already found some hard to find Reebok manuals. I guess they have the TR3 for download on their site.
May 17, 2009 | Reebok Exercise & Fitness
Reebok 8500 ES treadmill - noises
You should check the motor and the rollers. There are oil joints that can possibly use some oil or the motor is going bad. The way to check the motor is with a volt meter or to check it with your hand after running it for 5 minutes without a load on it. If it is very hot then replace the motor. Most noise problems come from the rollers bearing which usually just need to be oiled and not replace. There is a cover behind the big roller that can be removed to look at the problem
Feb 11, 2009 | Reebok 8050 ES Treadmill
Oil can caption on my reebok fusion treadmill (rev10301)
It means that you need to spray silicone between the belt and the platform it runs on
Jan 10, 2009 | Reebok New York Giants Eli Manning Jersey
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Dec 02, 2008 | Exercise & Fitness
Reebok New York Giants Eli Manning Jersey Logo
1,086 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
