Question about HTC G1 Smartphone
G1 hard reset prob - HTC G1 Smartphone
Posted by prado_aakash on
lynwood
  • 32 Answers
If the problem you are having is figuring out how to do a hard reset..this is what you have to do.
go to your settings menu scroll down to sd card & phone storage go to factory reset data read what it describes and if that is what you want click on reset phone
this will reset your phone to factory default.
Posted on Oct 14, 2009
How do i factory reset HP / Compaq ElitePad Tablets 900 G1 Tablet P windows 10 without activation key i dont have a system restore image either
You can use a key reader software program to read the key, but without the Windows 10 installation image you are stuck. They are usually on a hidden partition on the hard drive? If not, because it is a Compaq and has a custom Windows image, you would have to buy a replacement from Compaq.
Number one tip, have computers made for you and buy a standard OEM Windows Operating System.
The fact it is a tablet makes things a lot easier, you just do a hard reset as described here.
Hard Reset HP ElitePad 900 G1
These videos suggest that the Operating System is Android and not Windows so you don't need an activation key.
compaq elitepad tablets 900 g1 tablet hard reset Google Search
Sep 23, 2018 | HP Tablets & eReaders
Tip
How to hard reset or factory reset T-Mobile G1 phone
Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory.
Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
  1. Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
  2. Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
  3. Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
  4. After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
  5. Next, press 'Alt+W' key (to factory reset it)
  6. Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
  7. The reset is complete.
on Feb 25, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i...
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Jul 27, 2011 | HTC G1
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
Now to wipe the device clean:
3. Press Alt+L.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
When i turn my g1 phone on im getting a blank screen.i have not damaged my phone so what can i do to reboot it and try to fix it.
follow this link for a hard reset of your phone:-
http://www.dreamstrikes.com/others/22597-htc-google-g1-hardreset.html
WARNING: hard reset will delete all data on the phone memory.
Oct 28, 2009 | HTC G1
How do you hard reset g1?
If your T-Mobile G1 Google smartphone is not responding or is frozen, you may have to opt for a hard reset. Here’s how:
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
3. Press Alt+L.
Sep 24, 2009 | HTC G1
G1 charge light is not on but the phone is charging
Had a similar problem on my HTC (same maker of the g1) touch diamond, the charge light/indicator would stay on even after i took the cable out.
It could be just lag. Try doing a soft reset, where ever the reset button is on the G1 (Inside the back case?) If that doesn't help do a hard reset which deletes all data/settings (other than your carriers settings, your phone will still work), you would have to look in your manual, as I dont have a G1.
Feb 27, 2009 | HTC G1
G1 keeps frezing up. tryed to reset but it still frezing up.
do a hard reset.
3. Press Alt+L.
Jan 21, 2009 | HTC G1 Smartphone
Froozen
do a hard reset.
3. Press Alt+L.
Oct 24, 2008 | HTC G1 Smartphone
HTC G1 Smartphone Logo
250 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Marvin
Marvin
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
