Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Posted by flomotion on
Anonymous
    Scholar:
  • 120 Answers
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Posted on Oct 13, 2009
2006 mitsubishi tv WD 62627. Tv wont come on i hear a click when I hit the power button. Blinks green on timer for about 60 sec then goes to solid yellow light on status. Error code 46.blew fan out.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the fault circuit section inside it. http://electronicshelponline.blogspot.com/ Visit the site linked here to know more details about the blinking codes.
Feb 18, 2017 | Mitsubishi Televison & Video
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Yellow status light blinking
tour air filter cover door is either not tight, or off, or the small switch behind it is bad. it is on the side opposite the ac plug.
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
