Question about Plumbing
I have a booster pump to increase the water pressure to my RO.The problem I have is that when I initially turn my pump on the motor hesitates to turn for around 3secs before it starts.Please could you help
Posted by jamie_hylton on
Anonymous
    Champion:
  • 205 Answers
You want to check and see if it has a unload er valve to the unit. also check the amp,s to the unit. example 12 amps to run 24 to start. check your starting compositor. good luck
Posted on Oct 13, 2009
I hooked up a RO system to my purlogix water cooler n it’s not dispensing water
There might be a low pressure sensor inside the purologix system that is preventing the cooler from dispensing water. In that case you may need to install a booster pump to increase water pressure into the storage tank of the ro system.
Check if you installed the ice maker correctly as well.
https://www.wecofilters.com/pub/media/productattach//i/c/ice_maker_kit_manual.pdf
Nov 16, 2017 | Water Filters & Coolers
What causes my booster pump to increase pressure even after I shut power and or water supply off?
something wrong here. your incoming pressure is 4 psi ( tank pressure to the pump and you use a pump to boost pressure to a maximum of 65 psi at which point the pump is shut off ( all taps close off)
yet with no pumps running the pressure goes up to 100 psi
Find where you are getting pressure in that is making the pump leak
if you have 100 psi to the pump when it is turned off, then it would not be turning on ( power on) as the shut off pressure is set at 65 psi and the line pressure is 100 psi
Sep 27, 2016 | Grundfos MQ3-45 1 HP Pressure Booster...
How does one increase the pressure in the holding tank
If by "Holding Tank" you are referring to the bladder tank for your RO, then you need to turn the water off to the RO system, drain the RO tank of any water, check the pressure with a tire gauge at the air valve (just like there is on a car tire). A 3 gallon tank should have about 7psi of air.
RJ
Oct 29, 2011 | Culligan Under Sink Water Filter
Motor on reverse osmosis runs constantly
If this is a booster pump, many booster pumps like Shurflo have an adjustment at the top (allen screw) to back off on the pump pressure, turn to left to back off on pressure. If it never shuts off this can be an indication of a bad membrane, capillary tube, flow restrictor or automatic shutoff, causing all the water to run to drain. If you have low quantities of water, but pump always runs, this could part of the problem. Also high TDS (total dissolved solids) will cause the pump to work more. The higher the TDS 500+ppm the harder it is to produce quality water. With high TDS it's almost like taking muddy water, running it through filters and getting drinkable water. So the RO and pump have to work much harder to produce any quantity and quality of water.
RJ
May 01, 2010 | Culligan Under Sink Water Filter
Ro system tank will fill completely
Use this chart to pinpoint your issue and a possible fix. Most replacement parts if necessary can be found at https://www.freshwatersystems.com/c-67-parts-accessories.aspx.
Oct 08, 2009 | General Electric FX18M GE SmartWater...
Pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Jul 21, 2009 | Briggs & Stratton Garden
Under sink tank on older water filter onlyy produces 2 qt at one time. it use produce 1 gal. we have lime iron promblem water 3 flter culligun system under sink water filer system over20 yr old filters...
I am assuming based on your description that the system you have is a reverse osmosis system. If this is true, you most likely need to recharge the air pressure in your RO storage tank. I have included step-by-step instructions below. If you find that your tank is not holding air or the tank will not empty completely, the bladder inside the tank may be broken and the tank will need to be replaced. I have included a link to our selection of RO tanks as well. To recharge the tank you will need a bicycle tire pump and a tire gauge that will be capable of reading below 10 psi. If you don’t have one that reads in single psi increments, then a meter that starts at 5 psi will work.
http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
1) Close the cold water feed valve (if you can’t locate this on your system, you may be able to turn off the cold water to your sink)
2) With the RO tank valve on, locate the valve stem on the bottom or side of the tank. (this will look like the air stem on a bicycle or car tire)
3) Remove the stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave the RO
faucet open throughout the entire procedure)
5) If the current tank pressure doesn’t empty the tank, apply tire pump to valve stem
and pump a few times. Flow will increase and then gradually decrease as
pressure equalizes. Do not overcharge the bladder during this procedure.
6) Repeat step #4 and #5 until tank is completely empty. (Tank is empty when additional
pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5
& 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem
10) Open cold water feed valve.
11) The water is useable immediately; however, tank will take a few hours to completely fill.
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Jul 17, 2009 | Culligan Tools & Hardware - Others
Jenn Air Ice Maker Ejector Fingers Freeze Up
Hello, Yes you may be on the right track. Some manufactures like Jenn-Air, Viking, Sub-Zero, etc. require a higher inlet water pressure across the inlet solenoid valve to close the diaphragm after the ice machine stops calling for water. There are multiple solutions. But first, check the water pressure to your home to make sure you have 65-70 psi of pressure entering the home. Here is a link to our web site for a reasonably priced solution to increase the discharge working pressure from your RO System storage tank to the Jenn Air: http://www.puresafe.com/RO/html/eps-3tpp.html This is a modification that can be done to your system. It is a Patented Piston Actuated Permeate Pump that relieves the Permeate or Pure Water "BACK"-Pressure when the pure water enters the storage tank so the tank can store more water and build more working pressure. You could also increase the size of the storage tank, increase the size and daily production of the Membrane Filter to recover the tank water quicker, or add additional storage tanks for more volume of storage. Another method would be to use an "Atmospheric Storage Tank" with the RO System, and a Pressure Delivery Booster Pump to **** the water out of the storage tank and Pump it to the required location under higher pressure and flow when compared to the Conventional Pressurized Bladder Tank that you own now. The drill down path to our site for this information would be: www.puresafe.com, Purification, Reverse Osmosis, Residential, Pump Assisted Reverse Osmosis, EPS-3TPP, or other systems on that page. Hope this helped. Victor Kernes
Jun 25, 2009 | Jenn-Air JCD2389G Side by Side...
Have a kent r/o system dont know how to hook it up is there any way someone can help
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 13, 2009 | Culligan Under Sink Water Filter
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
To recharge RO System Tank:
3) Remove stem cap.
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
Mar 19, 2009 | Culligan Under Sink Water Filter
Plumbing Logo
41 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
