I am NOT too keen with 'universal remotes' because often the CODES listed are not accurate so your item (in this case a TV) may never respond without the proper code entered...
Some remotes offer a FISH method where you manually "step" from one code to the next... no fun but SOMETIMES your TV will suddenly respond again!
Now the IR SENSORS are rather rugged and seldom 'burnout'... but the board it mounts on is another story.
Your Service Manual can be found at the link below but the print is so tiny I was unable to locate the board with your IR SENSOR quickly... time is a issue and the link is a start!
One BAD point is that I found no USED boards for your model on eBay... not good.
Anthony
Toshiba 20AF43 Service Manual
Anthony
SOURCE: Toshiba televisoion problem
there should be a control on the set at the panel to switch this over to video. Might be in a door area or right up front if not U will to obtain a remote
SOURCE: remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
SOURCE: TV does not respond to Remote
Dear Mr.yeye,
There seems to be a problem with the IR LED of your television. solder the connections if any of them is cut. Also there can be loose connections. its better to contact the retailer from whom you purchased this tv
SOURCE: Remote sensor not working
either the sensor on the tv is going or the eprom chip will need to be replaced along with a crystal that is on the chip
