Question about Motorola Mobility SLVR L7 Cellular Phone
I have download some java games files from internet and I have paste it in my memory card phone.but when try open it at games&app in my phone and choose 'install new' file in that folder zero @ no file.so what should I do to install games in my motorola L7?
Posted by franze lupez on
Anonymous
    New Friend:
I can't Install software in Motorol L7. I had pasted .jar and .jad files in phone through bluetooth but it doesn't show any where in phone.
Although If I paste a image files it's showing in Picture.
so, plz tell me how to install any software in Motorola L7 mobile through bluethooth.
Posted on Oct 28, 2009
While opening game and apps menu, my sony ericsson w350i says operation failed... i've done master reset, but the problem is as it is.... help me???
Please check the format of the game you download,usually JAVA (J2ME) format is compatible game for this type of model.
Try to download on this free site : CLICK ME PLEASE
* After finishing download from your computer,copy and paste it to your memory card using a multi-media card reader.
* Then locate the game you download from your phone file manager on memory card ,then open the file.
* follow the instruction on installation and wait until the process is done.
Enjoy playing...
Thank you for visiting FixYa...
Jul 10, 2011 | Sony Ericsson Cell Phones
Java games & apps is not installing on my phone, don't kwon why pls help.
Hi, Here are the steps to solve your problem:
1. Download the desired java game in your PC.
2. Extract the downloaded game in your PC. 3. Connect your E63 to your PC via usb and run the 'Nokia PC Suite' software and transfer the extracted java game in your phone. 4. Click on the extracted 'nokia application installer file' in your phone. A wizard will appear asking you to complete the installation on. Just finish the instalation and its ok! :)
OR
1. Do steps 1 to 3 above but the only difference is you go to 'Data Storage Mode'
2. Copy the extracted 'application installer file in to some folder of you memory card.
3. Disconnect it from your PC
4. Go to file manager, Find the copied java game and click it.
5. Just finish the instalation and its ok! :)
Hope this helps! -jayps
Mar 07, 2011 | Nokia E63 Cell Phone
How to install third party java apps on my SAMSUNG GT5233A mobile phone??????????????? Is it really possible??? then, how??????????????
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
Feb 01, 2011 | Samsung Star GT-S5233 Cell Phone
How can i install .nes or .jar files in kisen n82+ . i had tried pc sync manager but no luck. also tried to copy all .nes to mythroad folder & also tried to copy under games folder still same result ....
Well, as for.jar files, I usually drag and drop to a java folder in the memory card. Then go to the file manager (memory card) search for the file that I just saved in the java folder and open it, it will prompt you to install, let it install. If it does not prompt you to open the file after installation, then just go to Java in the phone's memory and click on it, it should show the games already installed.
Aug 26, 2009 | Cell Phones
Unable to run games on samsung s3500
I had the same problem on my s3550. And now i found out from myself what the problem is. I Assume you have memory card and u are trying to install the games from the memory card. That is the problem. Just copy the game you want to install into the telephone memory and install it from there. It will solve your problem. I am so happy to help you. i hope you see this.
Aug 06, 2009 | Cell Phones
I HAVE SAMSUNG E1410 MODEL. CAN I DOWNLOAD JAR. OR JAD. FILE TO MY MOBILE????/
for installing java games n apps,first in the main screen,dial a no...."*#9998*4678255#.
then put the java app's jar n jad file in "other files" folder of the memory card n pres the center(play/pause) button to open it.
Jun 11, 2009 | Samsung SGH-D500 Cellular Phone
Please tell me exactly how to put java apps and movies on the i9
Ok, Its pretty simple to add java apps/games and movies to your i9. just
1) connect your phone to your pc via the usb.
2) go into your i9 phones memory card (the first of the two letters) i.e I = phone memory , H = memory card.. so go into the H drive.
3) Create a folder call 'JAVA' and simply drag your downloaded apps/games from your pc into your 'JAVA' folder on your memory card!
4) When you disconnect you phone, go to java in your phone menu then you can install the apps/games.
(step 3 only need to create 'java' folder once)
For movies
1) repeat step 1 and 2 above ^^
2) drag the movies from your pc into 'Movies' folder on memory card
3) disconnect phone from pc and you can now watch on your phone!
Note: i9 phone supports 3GP, AVI format only.
Jan 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
How to download java game from PC to Motorola V3x phone?
copy your .jad and .jar files to /a/mobile/kjava/ on your phone. once copied, on your phone, go to games, install new. your done. I use M-explorer to view/edit files on my phone and Jadmaker to convert my .jar files. Note: you must have both .jad and .jar files copied to your phone.
Jul 27, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
162 people viewed this question
Top Motorola Mobility Cell Phones Experts
Wasted space
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
