Question about Canon Office Equipment & Supplies
Have ir3170 with error code E000020-008 - Canon Office Equipment & Supplies
Posted by sajjawils on
Anonymous
  • 168 Answers
The sensor inside the copier is dirty. you have to remove the drum and clean the sensor assmbly
Posted on Oct 13, 2009
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Why is system software of canon ir 3170ci not loading?
LOAD SOFTWARE WITH PRINTER DISCONNECTED FROM COMPUTER THEN CONNECT PRINTER
Aug 17, 2014 | Office Equipment & Supplies
How to connect printer to computer without installation disc
Download mode error comes in Canon Ir3170 only when the shutdown was improper. Kindly off the switch on the right side panel and plug out from complete power supply. then reboot the machine. It will work perfectly.
Dec 02, 2013 | Samsung CLP620ND Printer
How to clear e004 for ir3170
The SSR has a short circuit.The DC controller PCB is faulty.The SSR used to drive the fixing heater is found to have a short circuit.The error must be reset in service mode COPIER - FUNCTION - CLEAR - ERR.
Feb 21, 2013 | Canon imageRUNNER C3170I Color Copier
Need user and password of canon ir3170
here's the original disk http://www.precisionroller.com/manuals-for-canon-imagerunner-c3170u/products.html. Try these Default system password: user:7654321 , psw:7654321 Default technician password. 11111111 Control panel password: user: Administrator , psw: password
Oct 30, 2012 | Canon ImageRUNNER 3570 Copier/Printer
KINDLY CLARIFICATION FOR IR3170 CANON ERROR CODE -E000070-0002
this is error code for ITB HP sensor detection error. As possible solution you can try to clean the ITB HP sensor and belt rollers.
Call service, the copier needs to be dismantled badley... :-)
Hope that helps!
Sep 13, 2011 | Canon imageRUNNER C3200 Copier
ERROR E000020-0081 in the screem IR3170 C
these is developer/drum related error.
One of possibilities can be that you need to clean the drum patch sensor that reads the drum surface or replace drum unit.
The drum patch sensor is located above the drum unit inside of copier. For better understanding you will need service manual. [email protected]
Hope that helps!
Jun 08, 2011 | Canon imageRUNNER C3170U Color Copier
How much the price of drum ir3170 TQ
hello
part number 4229A003AA, go to this link
www.iteminc.com they have five in stock
also, http://www.worldclassink.com/Canon-4229A003AA-Drum-item5406.html
please rate my service with 4 thumbs up
Dec 02, 2010 | Canon imageRUNNER 5020 Copier
My canon photocopier ir3170 is indicating e255-001,what fault do we have
you probably got the E225-001 error because the error that you say is not in the manual.
E225 CIS light intensity error.
At time of power-on or at the start of a job, the machine cannot find out whether the lamp has gone on normally for shading correction.
You must call a tech to verify the scanning lamp (xenon tube), CIS, inverter PCB, and reader controller PCB.
Nov 19, 2010 | Office Equipment & Supplies
Ir3170 error code e000732-0001
This error code is a communication error between the Reader Unit and the Copier (Printer Unit). Shut down and un-plug the Copier. Unplug and reset all the connectors on the rear and sides of the copier. One interface cable is responsible for communication between the reader unit and printer unit. This may solve the problem. Possible the cable is defective see if cable or cable socket is damaged.
This error also can be caused by a defective reader controller/DC Controller or Main Controller PCB.
If the simple cable check does not solve the problem a service call by a Canon dealer will required.
Mar 16, 2010 | Canon Office Equipment & Supplies
262 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
