Question about RCA 25450 4-Line Extended Range Multi Handset Phone
Want to turn off voicemail Don't know codes - RCA 25450 4-Line Extended Range Multi Handset Phone
  • Anonymous Oct 13, 2009
    Evidently I can reset the password sccording to the manual but I have to do it for each phone.
    What is the ## for the base unit?
Anonymous
  • 3,741 Answers
Voice Mail Box Management Options (Offsite) Your voice mail personal greeting can be changed from an offsite location. 1. When calling from an offsite location, wait until the phone answers then press the “ * ” (star) key to access voice mail through the auto attendant.
Voice Mail (VM) Every Cordless Handset connected to the system has its own voice mailbox. Each Cordless Handset has a mailbox number that is the same as it’s ID/extension number. The system can hold up to 100 minutes of messages with each message having a limit of sixty-four 64 seconds. NOTE: The default password is “0000”. Use this password when setting up voice mail for the first time, or after the password has been reset by the administrator. -------------- Configure VM Reset Extension Password(s) This feature allows the user to reset any extension password to it’s default “0000” password using the Base Unit. This feature is useful if an extension password has become unknown. Voice Mail Box Management Options VM box management allows the user to manage their extension password and customize their mailbox greeting. Change Extension Password 1. Press the Voice Mail button. 2. Enter your two-digit Cordless Handset ID followed by your four-digit password when prompted. 3. Press 5 or 6 on the Navigation button to scroll through the options until “VM box option” appears on the display. 4. Press the soft button. 5. “Change password” appears on the display. 6. Press the soft button. 7. Enter new four-digit password. 8. Re-enter password to verify. 9. If the passwords match, a confirmation tone will sound. The password is now changed and the system will return to the VM box option screen. 10. If the passwords do not match, the display will show “Invalid password Please re-enter.” Re-enter password or press the soft button to exit. --------------- for more help click this link direcly its listed on page number 31 http://www.rca4business.com/products/pc/pdf/instruction-book/H5450RE3.pdf ----------------- this will help.thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 13, 2009
Abbas John
  • 395 Answers
To turn off voice mail please dial ##002#, this would do the trick.
Regards
My ZTE phone goes to voicemail and never rings why?
It is either not registered on the cell network or is out of signal and defaults to voicemail. Or Voicemail has been enabled in error. find out from your local phone shop which code to enter to turn voicemail off. ( my provider uses 1261 on giffgaff to turn voicemail on and 1262 to turn it off.) It depends on the network as to what code you need to use.
Jun 02, 2016 | ZTE Cell Phones
Don't know password
feature 983
it will say log- press 1020000
it will say password-under that it says reset-push that soft key!! press release.
default will be 0000 once you access voicemail(981)
Jan 14, 2013 | NorStar M7310 Phone
Blicking white lite on top of the Uniden phone,and don't stop blicking
Without knowing the model of your Uniden phone I can't be sure, but if it's the voicemail light then you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 04, 2012 | Uniden Cordless Phone
Don't know how to listen voicemail
The procedure varies from machine to machine. Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual.
Jul 07, 2012 | Vtech 5.8GHz Analog Cordless Phone
'new voice mail' shows on the screen, but I don't know how to check it
You're subscribed to a voicemail system offered by your telephone company. Please contact them for instructions on accessing their voicemail system.
Apr 13, 2012 | Thomson 25952EE2 - - Phone
How do you get rid of a voicemail sign showing that you have one.when you don't have one
Call from alternate line, leave a voicemail and then from your phone go your voicemail, listen to it and delete it after listening to it complete, power off your device, remove the battery and sim card, put it back in turn it on and that should fix it.
Sep 22, 2011 | Cell Phones
I am new to this company and we have Norstar M7310 phones. How do i know if we have voicemail? If we do how do we set it up, if we don't how do we get it?
Hi there, in regards to voicemail, many service providers have different ways of setting up voicemail ... most of them have different input types of codes which you can enter with your phone keypads. This will either activate or disactivate the voice mail. The best thing is to ring them up and ask them for this code. I can help you further but then I will need all your details of your phone provider and I think this will be a longer process than calling them. I hope this helps and if you have any questions please do not hesitate to contact me. Good luck with that. Hope this helps.
Aug 18, 2011 | NorStar Meridian M7310 Phone
I can't get rid of my voicemail icon on my Motorola Cliq. I don't have a voicemail.
Do backup your data and do a factory reset going to settings . That should fix it .
Aug 05, 2011 | Motorola Mobility CLIQ Cell Phone
The voicemail light is fully lit(NOT FLASHING)it's not going away
First off we need to know what color it is.
Green-Dial "0" from the problem phone and that should clear it.
Red-Dial "Feature 99 Feature". If that does not work.
Leave a message in that users mailbox. From that users phone check and delete that message.
If neither of these operations work then you may have a bad port which means you may need a new station card. The part is an ESI(8)-U10-ETU, ESIB(8)-U10-ETU or an ESIE(8)-U10-ETU. The U10 might be different.
Let me know how these options work.
Nov 17, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Turning off answering machine
Hi
you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
Hope that helps?
Apr 26, 2009 | O2 X2i Cellular Phone
RCA 25450 4-Line Extended Range Multi Handset Phone Logo
1,144 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
k24674
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
