The read mechanism is stuck that is it is unable to move to the next section on the magnetic platen disk inside the hard drive \ It has come to the end - of - Life and need replacement. To recover your data before it completely dies is to put the drive into a usb case and connect it to the computer that has a large capacity drive and backup the drive contents. You will have reload Windows to the new drive.
The clicking noise is coming from the power supply relay. Is makes this sound when the TV is usually turned on or off but has become faulty. It will only get worse over time usually until the TV will no longer turn on anymore. You need to replace the power supply in order to fix the TV.
clicking = power supply not coming up
bad power supply, or bad (shorted) part causing power supply to not come up
with a volt meter we can troubleshoot
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
this is an indication that the power supply is working. The clicking noise shows that the power supply is booting up. If you still does not have power, it may be the main board that is not working.
