Toshiba DKT-2020-SD telephone Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My message button automatically calls another extension How do I get it back to answer my voicemail
george peters
Level 3:
President:
  • Toshiba Master 860 Answers
  • Posted on Oct 13, 2009
george  peters
Toshiba Master
Level 3:
President:
Answers
860
Questions
0
Helped
609319
Points
3471
The reason the message button is calling another extension is because that extension turned your message light on. to turn off the message light either press the msg button and have the extension answer the call or press intercom #409. You'll have to that for each message recieved til the light goes out.
Panasonic KX-DT543 Phone - Message button calls a phone extension instead of the voicemail extension. How do I change it?
To change the behavior of the message button on a Panasonic KX-DT543 phone, you will need to access the programming menu and change the settings for that button.
  1. Press the 'Menu' button on the phone.
  2. Press the '#' button followed by the 'Admin' button.
  3. Enter the administrator password.
  4. Press the 'Menu' button again, then select 'System Programming'.
  5. Scroll through the options and select 'Button Assignment'.
  6. Find the button labeled 'Message' and select it.
  7. Change the extension number to the desired voicemail extension.
  8. Press the 'Save' button to confirm the changes.
Samsung iDCS 28D Calls not going to VM after canceling a forward on no answer
It's possible that when you cleared the forward on no answer, the voicemail setting on your Samsung iDCS 28D was not properly restored. Here are some troubleshooting steps you can try:
  1. Check your voicemail settings: Dial 604 and press the "Speaker" button. Enter your extension number and press the "Speaker" button again. The system should confirm that you have entered the correct extension number. If it does not accept your extension, try dialing from a different phone to make sure that your extension is still active.
  2. Verify your call routing: Dial 601 and press the "Speaker" button. This will show you the current call routing for your extension. Verify that "No Answer" is set to go to your voicemail box. If it is not, you can change it by pressing the "Speaker" button and entering the appropriate code for voicemail (usually "72").
  3. Restart the phone system: If the above steps do not work, try restarting the phone system. You can do this by unplugging the power cable from the phone system for a few seconds and then plugging it back in.
If none of these steps resolve the issue, you may need to contact your phone system administrator or IT support for further assistance.
1helpful
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
When call goes to voicemail, it says call being transfered
I understand that you would like to bypass Auto Attendant for your lines.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercome
#208
Line 01
#208
Line 02
Do the same for all of the lines.
Go to your extension to program a voicemail cover button. Without it being on voicemail wont pick up
Press Feature 00
Select a button and call it Call Cover press it
Enter Feature 15
Feature 00
Press that button so the green light lights up.
Test.
3helpful
2answers
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
How do I interrupt the voicemail message?
You must turn off Automatic extension Privacy off on the voicemail extensions. If you have no idea what that is, then I would suggest calling in a local vendor, as it is a little difficult to do over a forum...
My M7310 keeps calling another internal extension, and it wont' stop.
I think an autodial button for that co-worker may be stuck, try jiggling the autodial buttons to unstick it.
Voicemail
When calling in from outside, at the welcome message, dial # > 9 > then the extension to be reached, ie: #,9,120
You will hear a different answer message, and be able to access your voicemail.
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i found, helped me out
2answers
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
