At start up, the green light illuminates for a few seconds, then goes to yellow, then to a light flashing red light where it remains until the 'on/off' switch is pressed, the light then goes solid red.
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
If the system flashes both the red and green light together, making a sort of yellow color, the system has overheated, and one of the main chips has become defective or detatched. This problem is known as the "Yellow-Light-Of-Death". If the system is still under warranty, contact Sony, and they should replace or repair it for you. If not, they will still repair it, it will just cost more, if the warranty seal is still intact. Hope this helps!
looks like the YLOD, you can search some fixes of refloating the solder with a heat gun or take it to a repair shop. lastly and most expensive is sending it into sony assuming its out of warranty if it is its 150 to fix it. If still under warranty then call them asap.
Toyota 4-Runner,
Solara 2003-10
Turn the ignition
key to the OFF position with the odometer reading shown. Turn the
ignition key to the ON position while holding down the trip meter
reset button. Hold down the button until the light goes off. Before
the light goes off, it illuminates for 3 seconds, flashes for 2
seconds, and illuminates for 1 second. If the system fails to reset,
the light will remain flashing.
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
h) Engine Oil Replacement Reminder
Light (for vehicles sold in U.S.A.)
This light reminds you when to replace
the engine oil.
This light will come on when the ignition
key is turned to “ON” and will go off after
about a few seconds.
When you drive for about 8000 km (5000
miles) after the engine oil replacement,
this light illuminates for about 3 seconds
and then flashes for about 12 seconds
with the ignition key turned to “ON” position.
If you continue driving without the
engine oil replacement, and if the driving
range exceeds 12000 km (7500 miles), the
light will come on after the ignition key is
turned to “ON” position. The light will remain
on thereafter.
If the light is flashing, we recommend that
you replace the engine oil at an early
opportunity depending on the driving and
road condition. If the light comes on, replace
it as soon as possible.
You need to reset the light after the engine
oil replacement. Reset the light by
following the procedure below:
1. Turn the ignition key to the “OFF” position
(For details, see “Odometer and two
trip meters” on page 136 in this Section.)
2. Turn the ignition key to the “ON” position
reset button.
off. Before the light goes off, it illuminates
for 3 seconds, flashes for 2 seconds and
If the system fails to reset, the light will
remain flashing.
I copied this from page 143 of the owners manual for the 2004 4Runner
Try a system reset:
1. Lift the headset off of the charging cradle (the base). Make sure the headset is turned off. The green light on the base won't be on if the headset is turned off.
2. Hold down the call answer button on the headset at the same time as mute button. The mute button is found on the little black wheel on the top of the headset. Use the tip of your finger to push it straight in.
3. Hold both buttons until you see a green light on the headset flash. It will be right below your thumb. Hold both buttons until the green light flashes for a series of 2 flashes. Then let go of both buttons.
4. Put the headset back on the charging cradle and wait 30 seconds. Lift it back off and try again.
5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle. Make sure the red light on the base is on and the yellow light is flashing.
2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down. Press both of those down until the red light and yellow light on the front of the base start flashing.
3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing.
4. Unplug the power to the base and then plug it back in.
5. Wait 20 seconds and try.
