Compaq Laptop Keyboard for HP Pavilion DV9000 - DV9700 Logo
Anonymous Posted on Jun 14, 2017
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into laptop. However when we attempt to start the laptop the keyboard lights come on for just a second or two and then the unit turns off. The blue power indicator on the front of the laptop does not come on or if it does only does so briefly and then goes out. Any ideas?
richie46
Level 3:
Top Expert:
  • Compaq Master 12,962 Answers
  • Posted on Jun 14, 2017
richie46
Compaq Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941567
Points
58151
Make sure the PS or adapter you are using is good. If it does the same with another known working adapter or battery then it appears that the cmos on the mo bo is corrupted. U might try disconnecting the hard drive and optical drive to see if unit stays on. But if it still goes out then it is definitely the board and a faulty peripheral is not to blame.
If board is bad, time to go shopping since the repair is not really cost effective given the cost of the board and the high labor expense involved.
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Jan 05, 2008
SOURCE: HP Pavilion ze5300 laptop/ Charge light on, when I try to power up it goes out and I have to reset to get light back. No boot
can you boot with the AC adapter? maybe the battery is completely dead.
Anonymous
  • 563 Answers
  • Posted on May 28, 2008
SOURCE: System shuts down
Hi labiancad
Were you able to see if all of the fans are working ?
Is there any of the LED's on the Projector flickering and what colour if they are ?
Anonymous
  • 304 Answers
  • Posted on Jul 16, 2008
SOURCE: Keyboard Problem
To activate StickyKeys
1.
Press the Shift key five times. A dialog box opens with instructions on how to set up the StickyKeys feature.
2.
If you click OK, an icon (a group of squares) appears in the notification area.
To turn off StickyKeys, press the Shift key five times.
Hope this helps you......
George
Anonymous
  • 3 Answers
  • Posted on Sep 28, 2009
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Anonymous
  • 7 Answers
  • Posted on Feb 01, 2010
SOURCE: Compaq Presario V3500. Power up - 4 beeps and flash power light.
Try to ask the company what is happening
HP Pavilion DV2700T PC Notebook - won't reboot.
go into bios next time it starts and turn off all power settings, same in control panel in windows and turn off sleepmode and hibernate.
1helpful
Hi, my DV9700 battery does not charge, adapter works but does not charge or run the computer on its own. I have had it checked and everything seems fine, they suggest the motherboard but I explained that...
This may sound stupid but try this, for some reason this seem to work on 6 and 9000 units with charging problems.
With the unit running, disconnect the battery and allow the unit to run for 60 seconds, then plug the battery back in, again with the unit running.
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
2helpful
HP Pavilion md5880n TV new lamp, left red light
I had the same problem the bulb was good but no power it was the transformer 975.00 under warranty from brandsmart. It worked for 90 days then the mother board went bad it cost 1000.00 they won't fix it .they gave me 1098.88 for a new one .Im gonig to sell mine for parts . I also have the stand for my tv also .
2helpful
2answers
My hp pavilion dv 9000 does not start.
Hard drives are cheap. Find out what type of drive this supports (i.e. ATA or SATA), and buy a new drive. They're quite easy to replace, too. You'll just need a recovery CD to re-install your OS (operating system) after you put in your new drive.
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
