Question about Sony KDS-R50XBR1 50" HDTV
I have recently experienced the green haze that most of the sony kds-r50xbr1 tv have been doing. what are my options?
Posted by spauldo on
Anonymous
  • 556 Answers
You don't have any Sony extended the warranty on these sets but it expired in June, 2009.
Posted on Oct 13, 2009
Sony KDS-R50XBR1 optical engine problem
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 27, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
My sony kds r50xbr1 has a green/yellow haze. They told me it was the Optimal Block, but instead of helping me fix it, they just tried to get me to buy another TV. I've read there is a lawsuit and/or...
To my knowledge, even if they offer you a new set, you do not have to take them up on it. They still have the responsibility to repair the set. I work for a Service Facility for Sony and I know the Optical Block is still being recalled. Our shop is still doing many of them. If you like the Set, Make them fix the set. It is a sweet piece of equipment when it is working properly.
I hope this helps,
Skyassoc
Oct 24, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
My tv is screen is green
Sounds like your optical block neeeds replaced, my kds-r50xbr1 just started getting the yellow-green haze who knew $3000 t.v's would only last 2 years urghh check out this link to sony and call the (866) 850-8674
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR50XBR1&news_id=219
Apr 15, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50" HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
