Question about Kodak EasyShare DX4530 Digital Camera
I have a dx4530 and when I take pictures, the screen is black. My guess is that there is a battery inside for the shutter and the battery needs to be replaced.
Posted by mcdias5 on
Pania Lee
    Genius:
  • Kodak Master
  • 1,099 Answers
No unfortunantly this is the mechanics of the camera.
DX4530 is no longer repaired by KODAK due to lack of spear parts.
However thay do offer a Trade up option where you can trade your existing camera for a favorable price to a Brand new model.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
How do you set the apeture on a Kodak Easyshare DX4530 camera?
1 In any Still mode, press the Menu button.
2 Press to highlight Exposure Compensation , then press the OK
button.
3 Press to select the Exposure
Compensation setting.
 If pictures are too light, decrease the
value.
 If pictures are too dark, increase the
value.
4 Press the OK button to accept the change.
5 Press the Menu button to exit the menu.
6 Use the camera screen to frame your
subject. Press the Shutter button half-way
to set the focus, then continue pressing
completely down to take the picture.
This setting remains until you change the
Mode dial or turn off the camera.
here is the link for the manual if the details are not clear http://www.retrevo.com/d/ds/progress?doc=9f1ccaf06b7e8ecedf71c821d3c1fb02&rk=0.5443618496384233
Oct 03, 2010 | Kodak EasyShare DX4530 Digital Camera
Nothing or black screen shows up when pic is taken
The problem is with the software in the camera! So take your camera to the nearby service center and do a format of your camera! That will fix your problem. Also check whether there is any problem in ur LCD screen!
Aug 01, 2010 | Kodak EasyShare DX4530 Digital Camera
It appears that pictures are being taken with the lens cap on - when that's not the case. In other words all camera indications are that the picture is "taken", but it is a black square. I'm thinking a...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Jan 12, 2010 | Kodak EasyShare DX4530 Digital Camera
I have a Kodak dx4530. Recently, when I push the
The camera is not recommending the picture, It could be overexposed, shaky or taken in the wrong SCN.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare DX4530 Digital Camera
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Black viewing screen and blank pictures
Luckyfourme,
Check to see that the automatic lens protector is opening and/or off when you experience black screen, as it should open letting light in when you power up the Kodak easyshare camera.
Good luck and Congratulations on your Daughters upcoming Wedding!
Mar 10, 2008 | Kodak EasyShare DX4530 Digital Camera
LCD wont show the View and No picture
CCD failure most likely. Format the card then try again or a new card. Kodak customer support for more info
Jun 08, 2007 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
