Question about Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
Whirlpool GR2FHTXVQ00 fridge. Water dispenser dispenses, ice maker does not produce ice. Seems frozen.
Posted by la_witte on
Charles T Nevin
  • 4,070 Answers
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Posted on Oct 13, 2009
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice maker is not working. Our freezer fridge side by side is about 8 yrs old...and now the ice maker is not making ice cubes. It is as if no water is getting to the machine. I have turned the...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Aug 29, 2009 | Freezers
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Mar 20, 2009 | Freezers
Ice maker broken
The ice maker likely needs replacing.
But ceck it to make sure its not hung up.
Does it have ice frozen in it or is it just turning arround.
Remove it and see if the heater underneath has a hold burnt in it.
Its just a plug in unit you can order one online.
Jan 13, 2009 | Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Freezers Logo
263 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
