Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the coil is ok, then you want to check the thermistor/thermostats. Remove the wires and tape them together one at a time with electrical tape and turn on the machine and see if it heats up ok...if it does then replace the thermostat/thermistor that is bad.
DO NOT LEAVE THEM TAPED TOGETHER. BECAUSE THIS BY-PASSES THE SAFETY OF THE MACHINE.
Good Luck,
Hope this helps
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
heatman101
