Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Tunning specification for a stihl 028 chainsaw?
What are the tunning specification for a stihl woodboss 028 chainsaw?
I need the carburetor settings and picture.?
Posted by rdelantra on
  • Anonymous Mar 22, 2014
    how do you remove the sprocket drum on a stihl 028 av super
Anonymous
  • 148 Answers
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
  • paul blomstrom Sep 19, 2013
    thank you so very much this is information i have been looking for i am sure this will solve my tuning problems
Anonymous
    Problem Solver:
  • 10 Answers
Screw both mixture screws all the way in then screw out 11\4 turns on the low and 1 turn on the high.
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
Stihl 028 woodboss runs fine for a tank of gas.
new air filter or wash it out with petrol to remove oil from the filter
Aug 03, 2012 | Stihl Garden
028 wb how do you gap the points with the flywheel removed
You need a cam tool--probably easier to see your Stihl dealer and have them set the points. Good luck!
May 04, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Stihl 028 Gas Tank off?
Any other manufacturer I would provide a link to an IPL. Stihl considers them proprietary.
Go here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A bunch of folk that enjoy all chainsaw. Please try search, find an applicable thread and join the conversation.
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Search for your saw and send a PM to an active member that replied to a similar request works best.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 17, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
8,599 people viewed this question
Top RTO Garden Experts
Dennis Key
Dennis Key
Bill Boyd
Tom Chichester
Are you a RTO Garden Expert? Answer questions, earn points and help others
