Fuji FinePix A340 Digital Camera Logo
Posted on Oct 13, 2009
Recently I turned on my camera and the screen shows black background with glittery sports on the screen. What needs to be done to repair?
Samsung LCD LN52A650AF - Glittery Red Green Screen Pixelations that moves around with changing figures on the picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
1helpful
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
My son has dropped his SP-500UZ which he really likes. The screen now shows white background with a number of blue & black "cracks/flashes" all pointing to a particular point. Presumably...
Repairs usually average about $200. Actually, most of the time these are not repairs but replacements with factory-refurbished cameras that gave someone else problems. There's no guarantee these problems won't crop up again. Your decision.
Feb 19, 2011 • Cameras
2answers
When I turn on the Z1U, the LCD shows no image but
The Sony has had some problems with the LCD screen since models made about 2004, so if your camera was made since that time.
The LCD screen on my 40D shows the image taken, or the live view image, but there are large areas of missing image. Almost like the picture has been laid on a black background then a large piece torn out...
If the Live View shows areas of total black, the LCD is probably faulty and needs to be taken to a Canon Dealer for repair/replacement. I believe the pictures are still okay on the computer in this case?
1helpful
Lens problem?! Black screen all of a sudden
the iris is stuck shut. try banging with the palm of your hand a few times to jar it lose. if its making crunching noise the gears are broken on lens housing. not econimcal to repair
BLACK VIEWER SCREEN WHEN IN CAMERA OR RECORDING
Your DSC-T1 has problem with CCD Imager and Sony will repair it free of cost. Please click Sony website and confirm camera symptoms and get details to proceed further.
Regards,
Cracked Screen i880
You should have this checked out by a qualified repair person at a Sprint Nextel service & repair center. Many full service centers can repair the i880 on site or order an advanced exchange to replace the unit.
1helpful
2answers
Black screen
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
