There is no known region hack for this model.
Symphonic players are built by Funai.
I am reporting region hacks for different Funai models.
The procedures below may not work, but that is all the information available.
I suggest contacting Funai and asking region hack for the correspondent model Funai WV806:www.funai-corp.com/6pdf/om/WV806.pdf.
Models SV2000 WV10D6:
1) Hit CS
2) 2,5,1
then the menus appear. You will notice a selection of self test
info that can be used to test the player, confirm the firmware both
Front End & Back End, upgrade the firm ware as well as numerous
other test modes.
3)Exiting the screens and returning to normal mode:
Changing Region code:
Hit CS
Then 6,5,0 for all region
From Videohelp.
Funai FDRV90E:
using the remote; press cm-skip, cm-skip, 5, 1
gives an info screen with many test options and displays
region code etc. I can not find a way to edit the screen
with the region code
From Videohelp.
If the hacks do not work, Try contacting Funai: Contact Funai Customer Support.
what the CS stands for?
I don't know, when I get the reply on my question I may reevaluate my asessment
