The ink failure error is caused by air in the ink feed tubes in your
printer. This happens when the ink in your cartridge runs out and the
printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair
solution to purge the air posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Please perform the steps given below and verify the results.
Step 1: Reset Product
If the error code does not display, the issue is resolved. If issue persists then perform the steps given below.
Note: If unit is In Warranty then I recommend you to contact HP technical support to replace the unit.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
