Atwood water heater - pilot light and flame malfunction
Atwood water heater Model G4-SM - pilot will light but not stay lit overnight... with pilot on, heating flame comes on intermittently- I've adjusted the shape of the pilot flame per drawing with no luck
Re: Atwood water heater - pilot light and flame...
Michael,
The thermocouple sensor may not be in the best position to sense that the pilot is lit.
Adjust the thermocouple mount or simply bend the thermocouple "wire" so that the pilot flame is touching the tip.
Check your propane tanks (are they full?), make sure the valve is on, then check to make sure gas is making its way to the hot water tank, if the pilot lights but won't stay lit your flame sensor is faulty.
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube. If flame is yellowish and small: then clean pilot tube and combustion parts. http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Try removing the thermocouple where it attaches to gas control, and
spray a little WD-40 in the hole, then spin a rolled up small piece of
steel wool in the hole as well, then blow it out with compressed air if
you can. Then reconnect thermocouple. Make sure thermocouple tip is
getting good flame under it, and if that doesn't cure it, then it's time
to replace gas control.
So are you saying that the first initial lighting of the pilot, without turning to on, works o.k., good flame etc, ? If not sure, try lighting pilot only, and leave setting at pilot only, and see if it's a good flame, and get back to me.
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
It may very well the thermocoupler that is fault. It is that bulb that sits in the pilot flame. when it goes bad or doesn't sense a pilot flame it shuts all gas off. It needs to be replaced. Inexpensive do it yourself fix. Good Luck _Ned_
