Question about GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
Posted by shailesh58 on
John Tripp
  • GE Master
  • 4,656 Answers
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Posted on Oct 12, 2009
  • John Tripp
    John Tripp Oct 12, 2009
    here is an example to look at but you will need to locate the correct model number listed at the bottom of the refrigerator and near floor and behind the fresh food compartment door to be totally correct on your replacement part number.
    Thanks, Again Sea Breeze
    Click Here=> Appliance Repair Point and Click
  • John Tripp
    You may also test the female plug for voltage with a voltage meter while someone presses the dispense water button. Use caution, don't touch the probes to you or not consider this is live voltage while the button is pushed. Sea Breeze
Ice dispenser has rust
The rust will conterminate your ice, please have the spiral ice dispenser replaced.
Jul 30, 2009 | GE Profile Performance 25.2 cu. ft....
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
I have a GE side by side refrigerator its about 7-8 yrs old it has ice and water in the door I replaced the water vavle last month but now it has stopped making ice but still dispenses water what might the...
If it's not the water valve, it's the icemaker. Since you have just replaced the water valve and it's not calling for water, I would say that the icemaker should be replaced.
Apr 04, 2008 | Refrigerators
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
368 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
