Turn on the hot water and it sounds like heater tries to turn on 2-3 times then shuts off and gives error code 11. sometimes takes turning unit off/on several times to get hotwater. gas company can't figure it out. help!
This worked for me in the same situation. There is a filter inserted into main gas/ water control valve that senses water flow restriction. The sensor is connected to the gas valve. If it senses inadequate water flow it tells the gas valve to shut down so the water in the heater won't boil. Very expensive part. If you do find the filter clogged, a sediment water filter shoud be install on the inlet side of the water piping.
