Question about Steinberg HALion 3 Full Version for PC, Mac (502014911)
Audible click/pop when starting program. ASIO
User experiences audible clicks/pops (ongoing) when starting program. ASIO option settings anyone?? I usually run all ASIO through Digi (001) and all is well, until I installed Halion.
Anonymous
Due to the DIGI001 ASIO settings, the HALion engine and program should be used as a plug-in (VSTi) in your master DAW, (i.e., Sonar, ProTools, Cubase, etc.) and it should fix the problem. Ensure that your drivers are updated and direct all signal traffic to the input device that is shared throughout your system or simply reassign your "patchwork" through the main DAW as mentioned above.
Peace
DJDIRTYDISHEZ
Posted on Oct 13, 2009
Testimonial: "It is still possible to use HALion in stand-alone mode, but the results are less than favorable. "
How turn on pop up blocker
If you are using IE which comes with your computer by default, follow the steps as below. I've attached a picture as a guide for you.
Click on "Tools".
Hover your mouse cursor over the "Pop-up Blocker"
Click on "Turn On/Off Pop-up Blocker" option.
You may also click on the "Pop-up Blocker Settings" to set your "Pop-up Blocker" blocking level and you can also allow pop-ups from specific websites by adding them to the exclusions list.
Apr 07, 2014 | Computers & Internet
How do I remove content control on my pc
Which operating system ??..
To Remove Parental Control Software from Windows XP
Click "Start" and then open up the "Control Panel".
Click on "Add or Remove Programs".
Wait for the program list to populate. Scroll through the list and identify the monitoring web software such as NetNanny, WebWatcher or similar.
Click on the web monitoring software.
To the right of the highlighted software is a button that says "Change/Remove", or two buttons, one "Change" the other "Remove".
Click the appropriate button that will remove the web blocking software.
If you get a pop up asking if you wish to continue, click "Yes".
The Windows Add/Remove utility will proceed automatically from this point on.
To Remove Parental Control Software from Vista or Windows 7
Click "Start", then open up the "Control Panel". A new window will open up, select "Programs and Features".
The heading will now read "Uninstall or Change a Program".
Scroll through the list until you find the web blocking software you wish to remove.
Select program.
The action "Uninstall" will appear next to the word "Organize" in the bar above the program list. Select "Uninstall".
Click Yes when the message box pops up asking if you're sure you want to uninstall the parental controls program.
The uninstall utility will take over from there.
To Remove Parental Controls on a Mac
Open the "System Preferences" folder.
Select "Accounts" under the "Systems" header at the bottom of your screen.
Select the user account name from which you wish to remove parental controls from the left hand column.
Uncheck "Enable Parental Controls".
Change Firewall Settings
A firewall is a security utility designed to thwart electronic access to a network.
Firewalls are absolutely necessary because, without one, your computer is prone to being exposed to Trojans, mal-ware, spy-ware and other kinds of viral infections.
However, in some situations it is helpful to alter the firewall settings to allow certain programs to run without being blocked.
This is important to anyone whom wants to know how to access Windows Firewall and customize its settings.
Go to the start menu and select "Control Panel."
Click on the Windows Firewall icon.
It looks like a brick wall.
Choose either "On," "Block all incoming connections" or "Off" under the "General" tab.
It is recommended to have it on and not advised to turn it off.
Click the "Exceptions" tab to choose which programs you do not want to be protected by the firewall.
Click the empty box to check the programs you want to add to the list of exceptions.
It is recommended to check browsers and file-sharing programs.
Click the "Advanced" tab to choose which network connections you want the firewall to protect.
It is recommended to check all connections because your computer could be exposed to viruses if left unchecked.
Click "Restore Defaults" under the advanced tab.
This may cause some programs to stop working and is not recommended if you do not have experience working with firewall settings.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Select "Tools>Internet options" Inside Internet Explorer, then click the "Security" tab. Press the "Custom level" button.
Sep 21, 2013 | Computers & Internet
Unsubscribe from homepay
Most of the spyware programs on the Internet that will infect your computer log the websites you visit so that they can launch pop-ups and advertise products for you to buy.
If you have recurring pop-ups caused by spyware that appear whenever you connect to the Internet, you will need to completely remove the spyware causing the problem.
The most effective way to remove all spyware from your machine is to use at least two different antispyware programs while your computer is in safe mode so that the spyware cannot open itself.
Navigate your web browser to a website that offers a spyware removal utility such as "Spybot" or "Lavasoft Adaware".
http://www.safer-networking.org/index2.html spybot
http://www.lavasoft.com/ lavasoft
Download and install the antispyware software.
Navigate to a second website and download a secondary antispyware utility.
Restart your computer and wait for the manufacturer's logo to appear on the screen.
Press the "F8" key repeatedly until a new menu pops up.
Scroll down through the list of options and highlight the entry labeled as "Safe Mode."
Open up the first spyware utility you installed earlier once the operating system has finished loading in safe mode.
Click on the antispyware utility's "Update Now" button at the left side of the window.
Wait for the program to finish downloading the latest spyware detection routines.
Disconnect your computer from its Internet connection either by unplugging its Ethernet cable or by powering off your wireless router.
Click on the "Search For Problems" button above the "Update Now" button.
Wait for the program to finish scanning your computer's hard drive for spyware, and then click on the "Remove Selected Problems" button.
Close down the antispyware program.
Reconnect your computer to its Internet connection.
Open the second antispyware utility you downloaded earlier.
Run the program's update feature and then disconnect your computer from the Internet again.
Run the program's scan, and then remove any problems it finds.
Reconnect your Internet connection and then restart your computer to finish removing the recurring spyware pop-ups from your PC.
Hope this helps
Stop Internet Pop-Up Ads
Increased control over your computer and its security means less worrying about ********* attempts and virus infestations.
Part of security control when it comes to your computer is stopping pop-up ads from appearing while you surf the Internet.
Pop-up advertisements are not only annoying, but can also make your Internet connection seem slow.
In addition, some pop-up ads are designed to trick you into downloading malicious spyware and programs, which is why blocking pop-ups is a vital issue to the health of your computer system.
Download the latest version of either Internet Explorer, Mozilla Firefox or Google Chrome.
All three of these Internet browsers contain built-in pop-up blockers.
Install the browser on your computer and open it when the installation process is complete.
Set the browser's pop-up ad blocker to its highest settings.
Click on the "Tool" tab in Internet Explorer and select the "Pop-up Blocker Settings."
Select the "High" setting in the Blocking Level drop-down menu to block all Internet pop-up ads.
In Mozilla Firefox, click the "Tools" menu and select "Options." Click the "Content" section and make sure the box that reads "Block pop-up windows" is checked.
Using Google Chrome, choose "Options" from the Tools menu.
Click on the "Under the Hood" section. In the Privacy section, choose "Content Settings" and confirm that the "Do not allow" radio button is selected in the "Pop-ups" tab section.
Download and install a free, pop-up blocking software program on your computer.
http://download.cnet.com/smart-popup-blocker/3000-7786_4-10282837.html
Set the software pop-up blocker to its maximum settings to block all pop-up advertisements. Add websites to the "exceptions" options in the blocker software to allow specific, safe sites from which you want to allow pop-up windows.
also
IE: 8 right click in the top toolbar select the command bar this will add it to the toolbar then on the far right hand side select the tools then from the drop down list pop up blocker make sure its turned on and settings
hope this helps
It's easy to learn how to stop pop ups, and you don't need to download pop up blocking software to get rid of those annoying ads. Just try these easy fixes before downloading a pop up blocker.
The first three methods assume you can use the software you already have. It's quick and simple, and you won't need any add-ons with these methods.
It takes only a few minutes to stop pop ups yourself, even if you are not technically oriented. If Internet Explorer 7 (IE7) or Mozilla Firefox on a Windows Vista computer but these steps should work for any Windows compatible computer (although it may vary some if you have a different version of IE).
Here are four easy and quick ways to stop pop ups on your computer. You can use any one (or more) of these methods to get rid of those pesky pop up ads within minutes.
How to Stop Pop Ups - Method #1: Use Your Settings on Internet Explorer 7
Step 1: On Internet Explorer 7, go to "Tools", then "Internet Options"
Step 2: Click on the "Privacy" tab
Step 3: On the bottom, under "Pop-up Blocker", click the checkbox to "Turn on Pop-up Blocker". Click "Ok".
How to Stop Pop Ups - Method #2: Use a Different Internet Browser (Firefox)
Try using Mozilla Firefox instead of IE because Firefox automatically blocks pop up windows (unlike Explorer). You can download Firefox at http://mozilla.current-version.com.
How to Stop Pop Ups - Method #3: Use Your Web Toolbar
You may already have the google or MSN toolbar installed on your browser. If you try this approach, you may also want to read my articles on how to stop pop ups with your Google toolbar and MSN toolbar.
How to Stop Pop Ups - Method #4: Download a Paid or Free Pop Up Blocker
If you've tried the above steps, and you're still having issues, then you should consider downloading a pop up blocker program.
Two reliable free pop up blockers include the Google toolbar and MSN toolbar. Another popular paid pop up blocker is at http://ivyliu.com/panicware.htm.
For everyday pop up blockers, the above methods should work. However, if you've tried all of these suggestions and you're still having problems with persistent pop-ups, then it's likely that you have been infected with spyware.
Summary of How to Stop Pop Ups
First, try changing your IE browser settings to block pop ups. If you have Google toolbar or MSN toolbar installed, then you already have a pop up blocker installed along with it. Try using the toolbars, or try switching to the Firefox browser.
Finally, you can also download a pop up blocker (free or paid). It's easy to stop pop ups without having to download pop up blockers.
If these steps do not remove your pop ups, then you may want to download a free or paid pop up blocker.
If that fails, then you probably are infected with spyware, which must be removed in order to get rid of ad pop ups.
But the above four methods should work to stop most pop up windows.
also if its interfering with your search provider
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have if don't need any of them you can disable or remove them.
if its a program you might have to uninstall it.
Jun 28, 2013 | Computers & Internet
Please provide me with the info of which Humming bird version is compatible with windows7
You can make it compatable for win 7. When you install the program, right click on the install icon. on the list that pops up you will see troubleshoot compatability. choose that. when the wizard pops up, chose the second option and click next. you will see a series of check boxes to help make it compatable. chose the first and third check box. click next. in the next window you can chose which version of operating system it normally runs under. pick the one that normally works (sometimes you just have to experiment for the right one). click next and click on the run the program button. install the program as you normally would. it should function properly after that.
Jun 14, 2011 | Hummingbird BI/Query User 8.0 Full Version...
I was playing Literati and i forgot to turn off the pop ups now i want to turn the pop ups off how do u do that
  1. I have given you info on how to do this on firefox first then internet explorer
  2. At the top of the Firefox windowOn the menu bar, click on the ToolsFirefox menu (Tools menu in Windows XP), and then click OptionsFirefoxEdit menu, and select Options...Preferences...
  3. Select the Content panel.
Uncheck to allow and check to allow this is in firefox
Advanced options Internet Explorer provides advanced configuration options through Pop-up Blocker Settings. To access these settings, open Internet Options, click Privacy and then in the Pop-up Blocker area click Settings to open Pop-up Blocker Settings. You can configure the following options:
  • Address of Web site to allow. Enter a URL and click Add to add sites to the Allowed sites list. Any site on the list can open pop-up windows.
  • Filter Level. There are three different filter levels that you can use with Pop-up Blocker:
    • High: Block All Pop-ups. The default behavior of Pop-up Blocker allows sites to open a pop-up window when the user clicks a link. This setting changes that behavior by blocking windows that are opened from a link. If this setting is enabled, you can allow pop-up windows to open by pressing the CTRL key at the same time that you click the link to launch the pop-up.
    • Medium: Block most automatic pop-ups. This is the default Pop-up Blocker setting. This setting blocks most pop-ups that launch automatically when a Web site is loaded into your browser, but doesn't block pop-ups that are opened when you click a link.
    • Low: Allow pop-ups from secure sites. This setting allows secure Web sites (those that use the https:// protocol) to automatically launch pop-up windows without requiring that you add them to the Allowed sites list.
Jan 10, 2011 | Computers & Internet
What are the yahoo settings to connect to outlook express
Hi there!
I did a bit of research for you and came across an article which has the answer you requested. Here's what it says to do:
Follow the simple instructions to download and install the Yahoo! AutoSync software. The URL for this free download is in the resources section below.
Open the Yahoo! Autosync software once it has been installed. The configuration process will automatically start.
Click to select Outlook Express as the application to which you want to sync Yahoo!, and then click on Address Book. Then click on "Next."
Set up the synchronization to be either automatic by clicking on "Yes," or manual by selecting"No."
Enter your Yahoo! user name and password when prompted for it by the AutoSync program. Do not include "@yahoo.com" after your user name.
Click to place a check mark in the check box if you would like to store your user name and password so that you do not have to re-enter it with every synchronization. Click "OK," and you will see a screen that confirms you have changed your AutoSync settings. Click on "Finish" and select the option to start your first sync now.
Jan 04, 2011 | Computers & Internet
My hp pavillion dv6000 wont start normally. in safe mode will start but continues to request product key when i log in with my password.
It seems to be an issue with some software that is conflicting with the operating system. I would advise you to clear the start first. The steps below would help you clear the start up.
For XP:
  • Click on the start button(with the windows logo on it) on the bottom left corner of the screen.
  • Click on Run.
  • A small pop up box would open at the bottom left corner above the start button.
  • In the dialogue box beside "Open : " type "msconfig" and hit enter.
  • System Configuration Utility would open.
  • On the top menu, identify and click on Start up.
  • Now, click on the button "Disable All", at the bottom right corner. This will disable all the start up programs. However, you will still be able to access all those programs from Start->All Programs.
  • Click on "Apply" and then click on Ok/Close. If "Apply" is grayed out, click on Ok/Close. If administrator password is prompted, click OK and proceed with the steps below.
  • You would see another pop box with 2 options, "Restart" and "Exit Restart" or "Restart Later". Do not worry, if you do not get this option.
  • Restart your computer.
  • Immediately after your computer restarts, you will see a pop box. In that box, CLICK TO CHECK THE RADIO BUTTON AND ONLY THEN CLICK ON OK.
  • If you forget this step, you will have to start over again.
  • Your computer should have now booted to normal mode.
For VISTA or Win 7:
  • Click on the Start button (with the windows logo on it).
  • Click on Start Search and type msconfig.
  • On the top, under programs, you will find a link for msconfig. Right click on msconfig and click on Run as administrator. Click on continue (in user account control box).
If you still face the same problem, you can download and install the BIOS update.
If any of the above steps do not work, then it could be an issue with windows updates and any other updates that might have created a conflict. In this case, restore the computer to an earlier date when it was working fine. For that, follow the steps below.
For XP:
  • Click Start.
  • Click Help and Support.
  • Type system restore in the Search box, and then press ENTER.
For Vista or Win 7:
  • Click Start vistastartbutton.jpg, type system restore in the Start Search box, and then click System Restore in the Programs list.
  • If you are prompted for an administrator password or confirmation, type your password or click Continue.
  • In the System Restore dialog box, click Choose a different restore point, and then click Next.
  • In the list of restore points, click a restore point that was created before you began to experience the issue, and then click Next.
  • Click Finish.
Hope all this helps you.
Still if this does not work, then contact an expert who can help you with doing more troubleshooting on this in recovery environment. In recovery environment, we can try sfc /scannow and check /r.
Good luck.
Dec 18, 2010 | HP Pavilion dv6000z Notebook
I cannot configure my gmail account with outlook
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
  1. Log in to your Gmail account.
  2. At the top of any Gmail page, click Settings.
  3. In the Mail Settings window, click Forwarding and POP.
  4. In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
  5. Click Save Settings.
  6. In Outlook, on the Tools menu, click E-mail Accounts.
  7. Click Add a new e-mail account, and then click Next.
  8. Click POP3, and then click Next.
  9. Under User Information, do the following:
  10. In the Your Name box, type your full name the way you want it to appear to other people.
  11. In the E-mail Address box, type your e-mail user name followed by @gmail.com.
  12. Under Server Information, do the following:
  13. In the Incoming mail server (POP3) box, type pop.gmail.com.
  14. In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
  15. Under Logon Information, do the following:
  16. In the User Name box, type your full e-mail address, including @gmail.com.
  17. In the Password box, type your password.
  18. Select the Remember password check box. Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer.
  19. Click More Settings.
  20. On the General tab, under Mail Account, type Gmail.
  21. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  22. Select Use same settings as my incoming mail server.
  23. Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server requires an encrypted connection (SSL) check boxes.
  24. Change the Outgoing server (SMTP) port number to 465. The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL) check box.
  25. Click OK.
  26. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be prompted to supply or correct it. Make sure your computer is connected to the Internet.
  27. Click Next, and then click Finish
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Mar 20, 2010 | Google Gmail
    Hi, every time I start an office 2003 product the licence agreement pops up, how can I stop that? Thanks
    Just try this trick maybe it works for you : Go to Control Panel Click User Accounts and turn-off User Account Control,then click ok to restart your computer.Start an Office program, accept the EULA, restart an Office program to make sure EULA doesn't pop-up, go back to User Accounts
    and turn User Account Control on, then click ok to restart your computer once again.BTW are you using vista?
    Jun 28, 2009 | Microsoft Office 2003 Small Business...
    Everything sounds chopped and screwed
    I had the same problem when I first got the program. I found that the program makes you use the provided USB adapter for both recording and playback.  Now, in order to let the program know that it is plugged in for playback(in your case,)  when the program starts, select the option for ASIO and select the one with the USB in the drop  down menu.  If the program starts without it, then go to options, audio hardware, and then this will pop up following one of the selections.  Now, mess around with some of the options in the ASIO settings(like I did) and eventually the lag will not be so bad, if that is your problem, I'm not next to you, so I can't help that much, but I hoped I helped a little.
    Jan 13, 2009 | M-Audio Session KeyStudio USB Keyboard
    Steinberg HALion 3 Full Version for PC, Mac (502014911) Logo
    272 people viewed this question
    Top Steinberg Computers & Internet Experts
    Lawrence Oravetz
     Grubhead
    Grubhead
    Harrie
    Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
