Philips 42PFP5332D 42 in. Plasma Television Logo
Question about Philips 42PFP5332D 42 in. Plasma Television
My phillips 42 inch plasma tv just clicks when I
My phillips 42 inch plasma tv is 2 years old and  just clicks when I turn it on.It would click for about 30 minutes and then come on, but yesterday it did not come on at all. I read on line that this is a problem with the lamp or ballast. The lamp could cost $110 to $175. What should I expect to pay a technician? If it's more than the lamp what else could it be? What is the ballast?
Posted by michele_k_pe on
5 Related Answers
Anonymous
SOURCE: blurred image on my phillips 42" plasma
same
Posted on Feb 19, 2008
Anonymous
  • 72 Answers
SOURCE: Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Posted on Apr 08, 2008
Mark Hammonds
  • 61 Answers
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Posted on Nov 19, 2008
Anonymous
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
Anonymous
  • 90 Answers
SOURCE: Phillips 42 In Plasma Blinking Red Light Only
blinking link means there is a problem with the software -- usually this is caused when a fuse goes bad or the power supply board needs to be replaced due to a problem --- most repair places replace the whole board - nobody fixed one broken part
My Phillips flat screen model 42fd9935/17 has started going black after playing for about 2 hours... you can still hear the sound, but the screen is black... the picture will come back after turning the tv...
The cost of getting this plasma fixed is not costwise compared to getting a new TV. I recommend NOT to get another plasma but get either an LCD or LED for the best quality compared with price. Plasma parts can be quite expensive especially for a 10 year old model or may not be available.
Will not power on
This will bge faulty capacitors in the power supply, Take the back of the TV and check the power board for capacitors that are bulged /swollon on top, they may also leak a brown like substance, usually they are around 1000uf / 10v
Change any that look suspect and if capacitor related this will resolve your issue.
Hope this helps
1helpful
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
2answers
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Phillips Plasma 42PF3320
I have phillips 42" plasma tv it has 7 red light flashes at start up and locks out
Phillips 42" plasma power problem
See if the following solution is relevant for you (it worked for me and was worth it):
http://www.fixya.com/support/t182302-maxent_mx_42vm11_turn
2helpful
42 inch techwood plasma no picture
the most common cause for this is the capacitor (1uf 630vdc)located at c19 on the main power board.the cost for this component is around 90p
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
