2003 Chevrolet TrailBlazer Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i open my drivers door my radio and dash lights stay on but they turn off when i open the other 3 doors ???2003 trailblazer
Anonymous
Level 3:
President:
  • Master 1,187 Answers
  • Posted on Oct 12, 2009
Anonymous
Master
Level 3:
President:
Answers
1187
Questions
0
Helped
527861
Points
4102
The door sensor needs adjusting. It may be loose.
Loosen the lock nut on the pushbutton sensor in the door frame.
Unscrew the sensor a little and re-tighten the lock nut.
ace_sterling
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 20, 2009
ace_sterling
Contributor
Level 1:
Answers
Questions
Helped
1108
Points
After starting my chevy trailblazer 2004 the chime goes off and then the radio turns off.  it is an aftermarket radio but it was working for 3 months, now wont stay on after starting.  it will come on and stay on if the eng is not started.  help me !
The lights and radio wont turn off when i open the door. 02 trailblazer
Look for a loose plug at the latch, or you might need to replace the latch. You can also try to spray some contact cleaner into the latch and work it in (open and close the door repeatedly)
1helpful
3answers
Navigator Door Chime goes off when car off and I open the door. Radio system stays on & interior lights go off when door shuts.
All this comes from the GEM module,You will need to repair the driver door lamp switch located in the door lock assemble.
Interrier lights stay on when i drive and when i turn off the engine the radio goes off while sitting and waiting it should stay on for a while
no doubt that door swich is not working .remove each switch and unplug 1 door at a time to locate.when light goes off that switch is broken. some switches are located on the door handle and will have to remove inside door panel.drivers door gets used the most ,so I would start there
2helpful
Same issue no radio,windows, locks but dash board electric works
Try unhooking the battery, turn key on, leave door open, then connect battery, start engine immediately. The battery saver module thinks it's saving your power!!
6helpful
3answers
Radio won't turn off.
The radio should still shut off after 20 minutes even if the door is not opened. If it stays on longer than this there is still a problem..
2005 Ford Expedition XLT, major electrical problems
You have a wiring harness problem
Take it to the dealer directly.......
"door open" dash light won't go off
the door ajar switch in the drivers door latch is is either shot or sticking.open drivers door spray some WD40 in the latch,open and close door several times and if the switch is only sticking this will free it up.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
