The error 1316 message usually means a previous installation of a software is
getting in the way of the new installation. It's kinda nutty that this
would cause a problem, but we live in a nutty world. The fix is to
download a free program from Microsoft that will totally and completely
remove the old software. Then the new version can load unimpeded.
try to open ur local disk properties-->on general tab use disk clean up.. if that not work properly
need to try Download: Microsoft Windows Installer Cleanup Utility from and run it to .u can download these here:
http://support.microsoft.com/kb/290301
good luck
Assuming that you didn't do a fresh install of windows, Do this:
When the blue screen with the HP Invent logo
appears, press the F10 key on the keyboard. (You
have only a few seconds to press the F10 key
before the normal startup process continue
Then Select Full System Recovery (which will erase whatever you had in computer such as personal files, etc). Pretty much your system will be back as Factory Image
Thanks
DiegoTech
