Question about RCA D61W20 61" Rear Projection Television
How do u find the bulb
Trying to find where bulb is on my 61" rca projection screen
  • 56 Answers
5 Suggested Answers
ladywinn
ladywinn
  • 5138 Answers
SOURCE: 61" RCA Projection TV Model #: d61w20
You could have shorted Yoke and if so you have to replace all 3 yokes another thing that can cause this is Capacitors on Deflection board cp150,cp114,cp120 If cp150 2200uf 16v is puffed up on top then it is bad ,so replace all 3 caps other 2 are 220uf 35v.
Posted on Jan 02, 2009
Anonymous
SOURCE: RCA D61W20 61 in. Rear Projection in need of a new screen
How much are you willing to pay??
Posted on Feb 10, 2009
Anonymous
  • 431 Answers
SOURCE: HD61LPW163 won't start after replacing the bulb
Hi I am Vortash before you go into the back you may find this is just as simple as pushing the Re- set button?.. the manual is available for this set ( same Chasis and interior workings ) under HD61LPW162 at ... http://www.safemanuals.com
hope this is of help if you have any further problems just post on this page and I will be notified I will then download the service manual and talk you through any possibilities .. Regards Vortash
Posted on May 22, 2009
Anonymous
  • 647 Answers
SOURCE: RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Posted on Nov 08, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: How to replace the bulbs for the RCA DD61W20 61
They have some kind of Black Tar on CTR boards holding them onto neck of Tubes, you will have to remove the Front and Back of TV in order to Change out the Tubes its alot of work removing 100 screws.I have no Idea Why RCA built them to be so hard to get to!
Posted on Jan 01, 2010
Screen is losinjg brightness. Seems to be fading and alot less bright. I tghink it is the bulb.
since this is a projection I would say that most likely the bulb is your problem. I also have a projection tv and like every 3-4 years i have to replace the bulb..
Jul 02, 2011 | RCA D61W136D 61 in. TV/DVD Combo
Lost picture but sound is on
almost certain this is a lamp problem, bulbs blow up
if you remove the lamp you can see if the bulb is broken inside.
Jul 19, 2010 | RCA HD61LPW165 61" Projection HDTV
61" tv quit working
This is a strange problem , but it sounds like you got a broken mirror.take the front (fresnel,lens) off and you`ll find out.
Nov 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
YOU MAY SUST NEED A BULB.. THEY GO OUT ABOUT ONCE A YEAR AND ARE CHEAPEST ON EBAY.
Sep 06, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
RCA HDTV
have u tried a new bulb. as the bulb aproaches the end of life is tends to do thiis i see this all the time at the shop... bulbs however not a cheap item. how old is the set has the bulb ever been changed how much is the set run average life of a bulb is 3000 to 5000 hours
Feb 15, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
RCA D61W20 61" Rear Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
