Corel WordPerfect Suite 8 Full Version for PC (WPSD80ENGO) Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kyocera FS-2020D Driver maybe not compatible w/WP 8
My WP was working perfect until the guy installed the new driver for the printer and now all I can do is type and save. I can't do spell check or anything. It is a Kyocera FS-2020D printer if that tells you anything. I'm thinking Corel and Kyocera just don't like each other very much and aren't going to work together.
Let me know if you know anything. I'm using Corel WP 8 which I know is a very old version, but it still works for me.
Anonymous
Level 2:
  • Expert 200 Answers
  • Posted on Feb 18, 2010
Anonymous
Expert
Level 2:
Answers
200
Questions
0
Helped
188693
Points
372
To verify it is a driver issue you can uninstall the printer driver and see if you get back the lost functions. If you do then it is a driver issue. I can't say I have run in to this before.
Kyocera fs 2100 keeps printing pages with funny symbols on them.
go to Kyocera website it will give you the driver you need have your printer connected to your pc and install current driver
How do I detach the transfer roller bushes of a kyocera fs-2020d?
if you remove the pcr assy from the drum unit you will need to put the assy on the table. With a small slotted screwdriver you will have to wedge between the black roller bushes and the gray support on the pinion side.
Best regards,
Marius
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
Windows 7/64 doesn't list my printer
The cd only has the drivers that were available when the printer shipped. You download the latest one here:
https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1100._.EN.html#WIN7
And yes, it does have drivers for both 32 and 64 bit Windows 7
My Kyocera FS 2020d needs to print from my ipad. I can't figure out how to hook it up to my linksys wifi router.
Go to Kyocera Support and follow these steps:
Under Choose a Product Category choose Printer ' Black and white printers. Then select ECOSYS 2020D under Product Model, then select Manuals under Select Sub- Category (see screenshot below)
Find the operation guide to set the unit up on the network. Then go to the app store and find Kyocera Mobile Print. it's a free app and it supports Kyocera Products specifically.
2helpful
How make factory reset on kyocera fs-2020d
Looking to get rid of 'Install MK' message - any way that i can reset so i dont have to purchase a main kit?
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
1helpful
Kyocera fs-2020d doesnt do multiple copies of documents
This message often shows up when the memory is full from one document (normally a large file) to fix it you have to add external memory
3helpful
2answers
I can't get a drive for laser printer kyocera fs 720 in pc with windows 7.
http://kyoceramita.com.au/fs720.asp has xp driver for fs-720
attach fs-720; windows 7 will recognise but fail to install
click on 'unspecified device fs-720' in devices and printers
click to upgrade/install driver
use driver specified above (xp)
should install properly
cheers
Top Corel Computers & Internet Experts
k24674
Kolbrun...
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
