How to turn on line? after a power outage printer shows offline.
Posted by mark253 on
Anonymous
  • 56 Answers
Turn it on?
Posted on Oct 12, 2009
How do i fix dell printer off line message?
Turn off directly from power and turn on.If it doesn't work follow this article instruction it will help to fix dell printer offline. How Do Fix Dell Printer Say Offline Using Windows Laptop Fixotip
Jan 02, 2018 | Dell Office Equipment & Supplies
Helo,after power outage,our printers doesnt work.It sad offline.Do you now we can fix them.We turn it of and turn on,but it doesnt work.Maybe we must install it again.
try this open your printer folder right click on the printer and make sure that the use printer off line is not checked. i have seen this be the case when ive lost power.
if these took a power surge during a storm the nvram chips are probably shot and your network pcb's will need to be replaced
Jun 14, 2010 | HP LaserJet P2015 Printer
Printer offline after power outage. Restore?
Hi, Joy.
Give these a try:
1. Right-click on your printer icon and select "Offline" to uncheck and bring it back Online again.
2. Let your printer cool down for at least 5 minutes. Power it on again.
3. If you are connected to a power surge protector, flip the switch and power the printer on to see if the printer powers on again.
4. Connect your printer to a different outlet.
5. If not a power issue, remove and reinstall the printer driver.
Hope this helps.
Sep 22, 2009 | HP Office Equipment & Supplies
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Set the printer to Offline.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press the Forms/1 key.
Press either Arrow key until display shows Test Diag.
Press the CPI/2 key.
Press either Arrow key until display shows Diag Prnt Cal.
Press the LPI/3 key.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Sep 11, 2009 | Tally Line Matrix T6100 Printer
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
After a power outage, my Brother printer,
First off, make sure that you have turned both the printer and the computer off and then turn them on(cycle the power). When you go to the printer in 'printers' be sure that the printer is not light in color, if it is, then it's failed to come back online or it's broken. When you say, 'I have tried going into the control panel and clicking on print offline', I take you to mean 'print online', because you don't want to print offline, you want it online...
The easiest way to solve this is to move the usb plug going into the computer from the printer from one port to another, this will force the computer to re recognize the printer. I see that this printer has network capability. I am assuming, that the printer is connected via USB and not Ethernet. [USB, rectangle the size of your pinky, but narrow, Ethernet looks like a big phone plug]. If you move the plug from one USB slot to another and you don't hear the hardware connect sound(low tone then high tone), then your printer may be broken. It is possible if it is broken that the Ethernet port still works, but using that is beyond this discussion.
Good luck,
Brett
Mar 12, 2009 | Brother MultiFunction Center MFC-440CN...
Printer offline
Click Start , Printers And Faxes
OR
Control Panel , Printers And Faxes
right click the printer and untick "Use Offline"
Jan 27, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
81 people viewed this question
Ekse
Marvin
Marvin
