FYI, the pump does not have a valve which prevents the water from leaving the tub during wash cycles.
If you were to remove the drain line from the machine the water in the tub would siphon.
I think you are moving in the right direction by replacing the drain tube. Also inspect the other connections from the tub to the water pump and water pump to drain tube..
Good luck...
