Question about Kodak EASYSHARE 5100 All-In-One Printer
How do i do a wireless connection between computer and a kodac 5100 all in one printer
Posted by bheinrick on
Sibananda
    President:
  • 987 Answers
Http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf
follow this manual ...
  1. Check the Wi-Fi Status Indicator on the front of the printer:
  2. Status: Do the following: Off
    1. Select Menu (or Home)>Network Settings and press OK.
    2. Select Turn Wi-Fi Radio On and press OK.
    3. Select Wi-Fi Setup Wizard and press OK.
    4. Select the SSID (name) for your router.
    5. If you have your network secured, you must also enter your password.
    Blinking
    2. Select Wi-Fi Setup Wizard and press OK.
    3. Select the SSID (name) for your router.
    4. If you have your network secured, you must also enter your password.
    5. NOTE: If the message Your printer is already configured for Wi-Fi network appears, your printer cannot find your router.
    6. If this occurs, check that the router is turned on and located within 100 ft (approximately 30 m) of the printer.
    On The WiFi Status Indicator could be on, but you could be connected to the wrong router if you used the manufacturer's default SSID and password when you set up your router. If this is the case:
  3. Select Menu (or Home) from the printer control panel on the front of your printer.
  4. Select Network Settings and press OK.
  5. Select View Network Configuration and press OK.
Place the KODAK All-in-One Printer Software CD into the CD-ROM drive on your computer.
Follow the on-screen instructions. Do one of the following depending on the version of KODAK All-in-One Home Center Software:
  • When the KODAK Printer Setup Utility screen appears, select how you want your printer to be connected:
    • USB cable
    • Wireless Wi-Fi® connection
    • Ethernet cable
Posted on Oct 12, 2009
1 Related Answer
Anonymous
  • 15 Answers
SOURCE: kodac 5100 AiO printer--how to scan pic. and send
Connect your printer to the computer and make sure that you have the latest Kodak All in One Home Center software installed on the computer.
To download the latest version of software, go to the link below:
kodak.com/go/5100downloads and install the software.
You can scan a picture either by using the scan button on the printer or by using the Kodak Home Center software.
There is one more way of scanning the picutre from MS Paint application in Vista and XP.
  • Open MS Paint and go to the "File" option on the top left.
  • In the Drop down menu, select "From Scanner or camera".
  • It will give you the choice to choose the desired USB device so selct the Kodak printer/scanner and the file be scanned in Paint.
  • Now you can save it as an image on the computer.
If you are looking for a manual, go to the link
kodak.com/go/manuals
On this webpage, you can view and download manuals for all Kodak printers as an Adobe(.pdf) file or as .html file.
Posted on Oct 15, 2009
Find a printer that allows me to run Windows XP safely? I have an old computer that is running XP home. I have been advised that all newer printers will not work safely with XP. Where can I buy one
I have a kodac ESP Office 2150 printer and I still have my windows xp on my computer and it works great with windows xp it conects with cable or Wi Fi but I don't have any problems with it!
Jan 04, 2015 | Microsoft Computers & Internet
Hi I have a Dell inspiron 5100 lap top. I have
  1. Right click my computer
  2. go to properties
  3. device manager
  4. you will see network adapter and under that will be wireless adapter
  5. click on wireless adapter
  6. go to properties
  7. See if device is working properl
Dec 02, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
How do I set up my kodak easyshare wirelessly?
Depends if you have a wireless model or not. With this amount of information I'd suggest you go to www.kodak.com/go/wifi
Oct 20, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodac 5100 AiO printer--how to scan pic. and send to computer file...can not locate manual
Oct 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I can print from main computer, but are now unable to print from wireless laptop, which I could 2 week ago
assuming that your printer is physically connected to your main computer, and that your laptop is wirelessly networked with your main computer,
then you need to have the main computer on as you attempt to print from your laptop
Oct 03, 2009 | Acer Aspire 5100 Notebook
Wireless connection
hi,
welcome to fixya.com
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
My kodak 5100 printer is having problems printing black text
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the printhead:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Cell phone photo xfer
att/lg will not allow bluetooth wireless xfer of phots to a kodac kiosh... so i purchases amini memory card(which comes with a scandisk micro adapter.) i used my handset phone to move each photo to memory.......then used the card to xfer to my printer/ computer.. long process, but it worked...... thanks anyway...... i will keep you in my address ' RONZ5
Mar 31, 2008 | RIM BlackBerry Pearl 8100
Wireless Network Connection is very weak
Is the router near to any electrical devices that could be causing interferance? Try putting the router in a different location.
Dec 29, 2007 | Acer Aspire 5100 Notebook
Kodak EASYSHARE 5100 All-In-One Printer Logo
368 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
