Go to menu. You know the setting icon right. Click on that icon.In that one select first ooption named general settings. in that ,you want to select third option will be the language option in that one you can see the english option.....Hope this will helps you...Thank you...
To set the phone language:
To set the writing language:
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Tamil language not support
Go to setting (screwdriver icon) select and key down to "language" (second item on list) and select "English" or "As SIM"
SOURCE: Change language setting from Thai to English
Hi
The problem is ur phone is in automatic language.
Look in your manual, page 50. To change the language press
Settings (Last option in main menu)- Other settings(last option in settings menu) - initial set up(second option in other settings menu) - languages(seventh option)- English
- (normally the second option in languages)
SOURCE: By Master Reseting english language has been changed by Chinese then how to restore English language
Hi There is a tool you can use to flash your firmware to the language you want. It is called Fighter. If you want it, I can help you to flash it to the firmware of your choice either Chinese, French, German.... I can even upgrade your P900 to P910 version so your external memory can recognize the Memory Stick up to 1GB but instead you cannot use the Bluetooth Function after upgrading. You can use the Jabra a12 Bluetooth Adapter instead to have a new connection with Bluetooth. I has my P900 working this way and it works Great. This tool can even unlock your phone too to the most latest firmware. Regards, pingping
SOURCE: language problem
Hi Vasu,
to change your phone language you need to go into settings then profiles the language scroll down 3 one down click select and all
language will display you can them change back to english language
