Question about Maytag MSD2756G Side by Side Refrigerator
Have a Maytag side by side with ice maker...it quit making ice within 3 months of installation. Had one repair man look at it...said that it was a common problem w/ Maytag...hit ice maker with his fist a couple of times and it worked for a week or so...now it does not fill trays, nor seem to cycle...cooled water spout does work.
  • 396 Answers
Assuming it's not still under warranty, I would probably replace the icemaker components inside the freezer.
The repairman's "fix" indicates that there is some kind of problem with the "brains" of the icemaker. It would probably not be cost effective to try to diagnose and fix the problem.
Posted on Oct 12, 2009
6ya staff
SOURCE:
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hgkl
Jun 19, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice maker quit working when I replaced the water filter.
Your model Maytag comes with an electronic ice maker and if you just recently changed the water filter the water should be dispensed for 2 or 3 minutes or until any air that may be trapped in the lines is removed. If air is sill present in the filter the ice maker opens the water control valve for about 7.5 seconds. If air that is what the ice maker will get until the air is completely purged from the system. If you fill that you have past that point then pour tap water into the ice maker and let freeze. After the water freezes the ice maker should cycle and dump. If not the the ice maker core may need replaced. If yes it dumps then the air may not yet purged or the water control valve for the ice maker side may be defective. This is one of those wait and see repairs. I will send you a link to the copy of the service manual and page 71 begins addressing the ice maker. Thanks, Sea Breeze
Dec 22, 2009 | Maytag MSD2650H Side by Side Refrigerator
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
My Maytag MZD2766GES is not filling the ice maker.
there is a test button underneath the ice maker press this making sure you put a tray of some kind underneath this will operate the icemaker and go through its empty and fill cycle ,if it does not fill it will be the solonoid valve
Jun 27, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker not working
I would check the ice maker assembly itself, perhaps an ice cube has not completely exited the mould,and is preventing the ive maker form cycling again
Jan 10, 2009 | Maytag 23 cu. ft. Side-by-Side...
Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Jan 02, 2009 | Maytag MSD2754G Side by Side Refrigerator
Mfi2568aes ice maker
it is under warranty call for service
Jun 20, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
156 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
