Question about Texas Instruments TI-86 Calculator
How do I find the cube root button on my TI- 86
Posted by beengl5357 on
k24674
  • Texas Instru... Master
  • 8,091 Answers
There is a relation between roots and fractionary powers.
2nd root (square root) of X = X^(1/2) power 1/2
3rd root (cubic root) of X = X^(1/3) power 1/3
4th root of X = X^(1/4)
n-th root of X = X^(1/n)
Use the raise to arbitrary power key labeled as a caret [^] or [X to the y] or [Y to the x]
Hope it helps.
Posted on Oct 12, 2009
I have a casio fx-115ES and I want to do a cube root without answering in decimal forms
Sorry, but the fx-115ES can only display square roots in radical form. Cube roots are beyond its symbolic capabilities and will always be in decimal form.
Mar 08, 2013 | Texas Instruments TI-86 Calculator
How to calculate cube root on simple calculator
That depends on how simple a calculator. I'll give some examples below for calculating the cube root of 8.
On a TI-86, press 3 2nd [MATH] F5 MORE F4 8 ENTER
If the calculator has a "^" or "y^x" key, raise 8 to the 1/3 power. Again, on the TI-86, press 8 ^ ( 1 / 3 ) ENTER
If the calculator has a logarithm key, take the logarithm, divide it by three, then take the antilogarithm. Again, on the TI-86, press 2nd [e^x] ( ln 8 / 3 ) ENTER
On a slide rule, place the hairline over the number on the K scale and read the cube root on the D scale.
Jan 10, 2013 | Texas Instruments TI-86 Calculator
How do i enter cube root on the ti86
In the MATH MISC menu you'll find the xth-root function. Use this to find the 3rd root.
3 xth-root 8 ENTER will give 2.
Sep 13, 2010 | Texas Instruments TI-86 Calculator
What are the steps to find the cube root of a number using the TI-86 calculator?
Use the root function in the MATH MISC menu.
To find the 5th root of 32: enter 5 then the root function and then 32 and then ENTER to get 2.
Apr 06, 2010 | Texas Instruments TI-86 Calculator
How do I cube root a number on my ti89 titanium calculator?
To find the cubed root of say...8, then you would type this into the calculator:
root(8,3)
Nov 02, 2009 | Texas Instruments TI-86 Calculator
What is the cube root function on the ti-86
look under math calc and there should be an x^3 key
Sep 29, 2009 | Texas Instruments TI-86 Calculator
How to find cube root.
What we call roots: square, cube ,fourth roots, etc. can be shown in algebra to be equiavlent to powers with fractionary exponents where numerator is 1 and denomonator an integer.
square root of a = a to the power 1/2
cube root of a = a to the power 1/3
n-th root of a = a raised to the power 1/n, n integer different from 0.
How to use calculator to calculate cube root?
If you do not have a specific (shortcut) key for it you use the key to raise to an arbitrary power [^ ], sometimes shown as [x^y]. The exponent will be 1/3. Do not replace 1/3 by its decimal approximate.
Cube root of 27 is entered as 27 [^ ] (1/3)
Hope it helps.
Sep 13, 2009 | Texas Instruments TI-86 Calculator
How to find cubed root on a TI-89 calculator
To find the cubed root (or any root) of a number, use the root() function.
If you want the cubed root of 125, you would type:
root(125,3)
Mar 06, 2009 | Texas Instruments TI-86 Calculator
Hi friend,hru?i want 2 know a shortcut 4 how to find a cube root of a given no.?
Use the general power key [^] to an exponent 1/3
Cube root of 27 is entered as follows 27[^](1/3)= 3
Hope it helps.
Feb 01, 2009 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
3,632 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Scoee Scoffer
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
