SOURCE: record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
SOURCE: I need to transfer video from JVC GR-770U Camcorder to my compute
Hi I am Vortash according to the manual for this unit available on http://www.safemanuals.com the unit is quite capable of downloading to a computer but yes it does require the correct software to do so .. you may find this is available from JVC support as a download .. it says that you can download to a usb terminal or a Rs socket with a compatible retail software .. hope this helps Regards Vortash
SOURCE: looking for sofeware for the jvc gr-D370u lost
Please go to the following link to download the drivers and manual for your JVC GR-D370.
http://camcorder.jvc.com/index.jsp
After you install the drivers you would be able to download and view them on your PC.
If you would like to touch the pictures or make major changes you should consider buying additional software.Good Luck!!!!!!
SOURCE: GR-D370 Mini DV Digital Camcorder: i have a jvc dr-d370u and i can't format my memory...
This model can accept SD card for up to 2GB only. You may be have more than 2GB card, otherwise there is an internal problem with your camera that needs repair. Hope this helps
